running `uninstall()` in PyScript doesn't work, but the `uninstall.iss` file is generated correctly. If I copy it and use it to run the uninstallation command in a command prompt, the uninstallation completes successfully.
Therefore, I'm ruling out a problem with creating the `uninstall.iss` file; there must be an issue with executing the uninstallation command through PyScript.
Thank you.
[SOLVED] Edt Package v2022 build 0.3.0 / Pronote v2022 build 0.3.0
olaplanche
- Registration: January 26, 2017 - 11:11
- Installed WAPT version: 2.6.0.16795 Enterprise
- Server OS: Linux / Debian Bookworm
I'm a beginner with WAPT. I haven't created any packages yet, but the installation on my network is already working.
Could you make your Pronote package available so I can test an import method other than the packages offered by TIS?
Thank you very much.
olaplanche
my packages are customized to create a connection shortcut to our Pronote server.
If you wish, I can modify my package with the DNS name of your Pronote server before sending it to you.
I'd like that, although I think I'll be able to change this setting when editing the package.
My Pronote server address is:
https://0350700w.index-education.net
Thank you
Thank you
olaplanche
Hmm, I must have missed something! I sent you a private message, but it's stuck in the outbox...
Did you receive it?
Did you receive it?
olaplanche
with pleasure.
Have a good start to the new school year!
with pleasure.
I'm writing because I'm also looking for this Pronote package to better prepare for the next school year.
Olaplanche, I would also be interested in your Pronote package. Would it be possible to provide it to me? (I would make the necessary modifications to personalize it for my school.)
Thank you. Have
a good day.
Thank you. Have
a good day.
olaplanche
Package sent!
Best regards,
Package sent!
Best regards,
