Package: tis-ccleaner
* French community support is provided on this forum
* Specify the installed WAPT version (1.8.2 / 2.0 / 2.1 / 2.2 / etc.) AS WELL AS the Enterprise / Discovery edition.
* Specify the server OS (Linux / Windows) and version (Debian Stretch/Buster - CentOS 7 - Windows Server 2012/2016/2019).
* Specify the OS of the administration/package creation machine (Windows 7 / 10)
. * As with any community forum, support is provided voluntarily by members. If you require sales support, you can contact the Tranquil IT sales department at 02.40.97.57.55
ssamson
Registration: June 20, 2014 - 10:29
April 23, 2015 - 12:10
Picture tis-ccleaner
Description:
A top-notch utility for quickly cleaning, repairing, and optimizing Windows
Steven Samson - Tranquil IT Systems
Feel free to leave us your opinion on Wapt in the forum, or to answer our questionnaires :).
ssamson
June 1, 2015 - 12:22
Update to version: 5.6.0.5219
- Added automatic package update function.
- Added CCEnhancer.exe lists
lowix
Registration: Apr 02, 2017 - 5:59 p.m.
April 2, 2017 - 8:53 PM
a big THANK YOU to the maintainers!
Have you noticed that a new version of CCleaner is available on the web?
They're up to version 5.28, while it's 5.23 in the repositories
April 2, 2017 - 9:40 PM
Good morning
The tis-ccleaner package is a well-made package ^^
It has a section:
if __name__ == '__main__':
    update_package()
This means you can update the package very easily yourself.
To do this, if you haven't already done so, install the waptdev package on your computer:
https://wapt.fr/fr/doc/CreationPaquets/ ... index.html
Then right-click on the ccleaner package in your private repository and select edit:
https://wapt.fr/fr/doc/Utilisation/util ... epot-prive
When PyScripter opens, in the setup.py section (in the tabs at the bottom), simply press CTRL+F9
The package updates itself automatically.
All that remains is to perform a test installation and then a build-upload
https://wapt.fr/fr/doc/CreationPaquets/ ... oad-direct
Right-click on build-upload on the left and then click on run.
Enter the username, --> admin
Then, on the next window, enter the password.
lowix
April 3, 2017 - 1:39 PM
tremendous !
agauvrit
Registration: Nov 17, 2016 - 10:25
September 18, 2017 - 2:11 PM
The CCleaner package has been updated to version 5.34; previous versions were removed due to CCleaner being compromised by a "Supply Chain" attack
Details of the attack are available here: It is imperative to remove the CCleaner package version 5.33.6162 If you have it in your repository, import the update to be safe from infection.
Alexander
