is it possible to disable the WAPT session setup from launching when a session is opened? Do all packages use this feature or only in certain specific cases?
Thank you
, Emilien
WAPT session setup deactivation
It is strongly recommended to maintain this startup behavior as it is necessary for certain packages.
The difference lies in the package's source code; if an action needs to be performed in user context, then it is mandatory to go through this "session setup".
If you still wish to disable the launch of session_setup, delete the shortcut created in the Start Menu for all users: C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Startup
Alexandre
Alexandre
