I recently started testing WAPT. Two weeks ago, I was able to create my first packages, put them on the server and deploy them.
Today, I wanted to create new packages. My installation and uninstallation commands work fine when I run them from the Python console. However, I can't send the packages to the server. Here are the messages I get:
Ligne de Commande : -ldebug -i build-upload "c:\Waptdev\sveil-Veyon-Master-wapt"
Building packages 1 packages
Building c:\Waptdev\sveil-Veyon-Master-wapt
Loading private key C:\wapt\ssl\SVeil.crt
ERROR building c:\Waptdev\sveil-Veyon-Master-wapt: 3152:error:0906D06C:PEM routines:PEM_read_bio:no start line:.\crypto\pem\pem_lib.c:703:Expecting: ANY PRIVATE KEY
0 packages successfully built
1 packages failed
List of errors :
c:\python27\lib\getpass.py:92: GetPassWarning: Can not control echo on the terminal.
return fallback_getpass(prompt, stream)
Warning: Password input may be echoed.
WAPT Server password :Error when uploading package : No package to uploadThank you for your help!
