Public directory/office cleanup
Di3s3l
Registration: Oct 23, 2017 - 1:27 p.m.
October 23, 2017 - 1:35 PM
Hello everyone,
I was wondering if there's a way to prevent the application shortcuts deployed to users' desktops from being added or removed afterward. These shortcuts are located in the C:\Users\Public\Desktop directory. Do I need to create a small script? Modify the deployment script? How would I do it?
Thank you.
:D :D :D :D
October 23, 2017 - 2:16 PM
You need to modify the wapt package and add:
remove_desktop_shortcut('Notepad++')
for example
Di3s3l
October 23, 2017 - 2:25 PM
sfonteneau wrote: Oct 23, 2017 - 2:16 PM You need to modify the wapt package and add:
for example
Thank you for your very quick reply :D :D However, if I want to do it for a large set of packages, is that possible?
Create a package to be launched at the end using the session environment, using a wildcard instead of the package name "remove_desktop_shortcut(*)" This would avoid having to configure the settings for each package.
