Reinstall deployed package
tdejesus
Registration: August 22, 2017 - 4:39 PM
October 26, 2017 - 4:44 PM
I created a package group (OfficeViewer) that installs two applications (Excel and PowerPoint viewers). Everything works.
I used a Microsoft uninstallation tool to uninstall my Office suite. This also uninstalled my viewers :| .
On the WAPT console, my viewers are still listed, even though they are no longer installed. I can't reinstall them via the console or using the command line: `wapt-get install OfficeViewer`.
Do you have any ideas?
WAPT 1.8.1 Community
Server OS (Windows Server 2012 R2)
WAPT Client: 1.8.1
Client Machines: Running Win10x64
October 26, 2017 - 4:59 PM
Have you tried incrementing the package viewer version to force the installation to start again?
tdejesus
November 7, 2017 - 6:31 PM
I've updated the version of the group containing the viewers, but the problem persists. The uninstalled packages won't reinstall.
WAPT Client: 1.8.1
November 7, 2017 - 7:50 PM
You should not increment the version of the group package, but the version of the viewer package!
tdejesus
November 9, 2017 - 11:27
Yes, it works.
Thank you
WAPT Client: 1.8.1
