with the 2016 version on Windows 7, installing this package causes an error when opening Office files from a desktop shortcut, for example. Is there a workaround, or should I uninstall it?
tis-disable-office-dde
- WAPT Expert
The package launches a .reg file in the user session. If you want to uninstall it, you'll also need to modify the values in the user context. The `uninstall()` function doesn't have an equivalent for removing things in the user context like the `session_setup()` function.
Therefore, for uninstallation, you would need to create another `wapt tis-enable-office-dde` package with the .reg file that changes the default values and execute it in a `session_setup()` call, just like the `tis-disable-office-dde` package.
