I have a technical problem. On my test environment, when I deploy the WAPT client (via GPO),
my client workstations don't have the WAPT tray launched at startup.
Your documentation states: "WAPTtray opens at session startup if the option was selected during installation. It is placed in the taskbar upon login."
However, since my installation is automatic and silent, I cannot select this option.
P.
WAPT TRAY
See https://www.wapt.fr/fr/doc/Installation ... waptdeploy
Add
to your GPO command line for waptdeploy
If you are not using waptdeploy but directly using waptagent.exe:
waptagent.exe /VERYSILENT /MERGETASKS= ""autorunTray""
Add
--tasks=autorunTray,installService,autoUpgradePolicyIf you are not using waptdeploy but directly using waptagent.exe:
Hello Jocelyn,
Alexander
- waptdeploy.exe allows you to run a lightweight binary (150KB) to verify that the WAPT agent installed on the machine is the correct version and, if necessary, proceed with its installation from the WAPT server by downloading the agent (waptagent.exe)
- waptagent.exe is the WAPT agent installer containing the public certificate.
Alexander
Oops, I typed too quickly.
After performing a manual installation, I have the answer to my question. WAPT appears in the notification area using two shortcuts placed in the startup menu of all users:
WAPT session setup: "C:\wapt\wapt-get.exe session-setup ALL"
WAPT Tray Helper: "C:\wapt\wapttray.exe"
Last question: What is the purpose of running WAPT session setup using the command indicated above?
- WAPT Expert
