I'm completely reconfiguring my WAPT server. I've removed all my workstations from the console.
I've recreated a GPO for the new client installation.
However, my workstations aren't showing up in the console.
How can I force them to appear?
Thanks in advance and have a good day.
Force the posts to reappear in the console
what result do you get in the command line?
https://www.wapt.fr/fr/doc/Utilisation/ ... t=register
Regards,
Alexandre
Regards,
Alexandre
Which version of WAPT are you using?
Following up on my little problem, I was thinking of cleaning up the database.
I saw this post viewtopic.php?f=13&t=621&p=1806&hilit=nettoyer#p1806
which I wanted to follow.
But I can't connect to the database when I run the mongo command
; I get the message "Command not found".
Could I get some help?
Thank you
Thank you
