I'm having trouble with the "é" when trying to switch my Windows 7 PCs from static IPs to DHCP. My batch file runs fine manually, but I'm having an encoding issue with WAPT. So I tried replacing utf-8 with cp850:
# -*- coding: cp850 -*-
print("Updating IP interfaces")
run (r'reg import DHCP-CLIENT.reg')
run (u'netsh interface ip set dns "Local network connection" dhcp')
run (u'netsh interface ip set address "Local network connection" dhcp')
but I'm back to my encoding problem with the message:
'ascii' codec can't encode characters in position 42-44: ordinal not in range(128) : faulty string is 'u'netsh interface ip set dns "Connection "on local network" dhcp
Thank you for your help
Accent problem
- WAPT Expert
You should avoid accented characters in run commands as much as possible. Input and output encoding are never truly controlled (this isn't a WAPT problem per se, it's a cmd.exe issue).
It's better to use wmi commands, which are usable in Python, something like this: `
import wmi
nic_configs = wmi.WMI().Win32_NetworkAdapterConfiguration(IPEnabled=True)
for nic in nic_configs:
nic.EnableDHCP()`
And don't forget to check in the package that there's a lease available for your machine before switching over!
import wmi
nic.EnableDHCP()`
steph.prevot
- Registration: June 15, 2016 - 1:00 PM
Hi,
thanks for the help.
WMI is way beyond my skill level, so I made a little script that runs at login and does the job perfectly.
Cheers!
Cheers!
