Agent installation and package update
hasop
Registration: December 13, 2017 - 10:31
December 13, 2017 - 10:43
I'm currently learning about WAPT and, despite the documentation, I can't find answers to these questions:
I installed the agent on a few test machines using FusionInventory's remote deployment (which we might eventually replace with WAPT if it proves successful).
Initially, I wanted to install it using waptdeploy, but an error calling a JSON URL prevented me from doing so.
So, I ran the command "waptagent.exe /VERYSILENT /MERGETASKS=""useWaptServer""" on the different machines, and it works fine. I can then deploy packages to these machines.
However, I don't have a notification icon on the client machines. Therefore, users don't have access to the features described in the documentation (running inventory updates, etc.).
What am I missing?
Furthermore, package installations only occur when I trigger them from the console. I would have liked to be able to give users control over the installation, and at worst, have it happen when the machine is shut down (or perhaps at a specific time of low activity, for example). This last point doesn't seem to be working. Is this related to the lack of a notification icon?
WAPT 1.5.1.9
Server: CentOS 7
Administration: Windows 7 Pro
Clients: Windows 7 Pro
Niaha
Registration: December 13, 2017 - 11:09
December 13, 2017 - 11:55 AM
Hi,
I had the same problem as you about 20 minutes ago, and you're partly responsible for finding the solution.
Follow the tutorial, and instead of "--hash3FHGH°05°Y54...", use /VERYSILENT.
I had no problems installing or getting the information back.
Best regards,
agauvrit
Registration: Nov 17, 2016 - 10:25
December 13, 2017 - 12:11
The list of tasks to pass as arguments to waptdeploy is in the online documentation, but it's just a little further down the page: https://www.wapt.fr/fr/doc-1.5/Configur ... waptdeploy
The option you are looking for is:
autorunTray
This was pointed out to us last week at the Paris Open Source Summit; we're going to reorganize this page
Furthermore, package installations only occur when I initiate them from the console. I would have preferred to allow users to control the installation and, at the very least, have it run when the machine is shut down (or perhaps at a specific time of low activity). This last point doesn't seem to be working. Is this related to the lack of a notification icon?
No, this point is related to waptexit.exe, the script that runs when the machine shuts down, only on workstations Windows Pro/Enterprise
By any chance, are the machines equipped with Windows Home?
https://www.wapt.fr/fr/doc-1.5/Frequent ... -lance-pas
Alexander
hasop
December 14, 2017 - 1:34 PM
I tried installing again using wapdeploy and here's the complete result:
C:\Users\XXXXXXXX>"D:\Downloads\waptdeploy.exe" --minversion=1.3.13.0 --wait
=15 --waptsetupurl="http://sw-wapt-test/wapt/waptagent.exe" --tasks="autorunTray
,installService,installredist2008,autoUpgradePolicy" --hash=30e783xxxxxxxxxxxe6
WAPT version:
WAPT required version: 1.3.13.0
Wapt agent path: C:\Users\XXXXXXXX\AppData\Local\Temp\waptagent.exe
Wget new waptagent from http://sw-wapt-test/wapt/waptagent.exe
SHA256 hash of downloaded setup file: 30e783xxxxxxxxxxxe6
OK : Hash of waptagent match expected hash.
Got version: 1.3.13.0
Unable to speak with waptservice... continue (Unable to download: http://127.0.0
.1:8088/tasks.json HTTP Status: 0)
Install ...
Launching C:\Users\XXXXXXXX\AppData\Local\Temp\waptagent.exe /VERYSILENT /MERGET
ASKS=""autorunTray,installService,installredist2008,autoUpgradePolicy""
Install OK : 1.3.13.0
Cleanup...
Because there is an error, the return code should not be 0 and is therefore considered a failure. However, the agent appears to be running, but there is no notification icon.
Furthermore, we are using Windows 7 Pro.
How can I check if waptexit is properly installed?
Could the problem causing the absence of a notification icon also prevent waptexit from executing?
Thank you for your help
WAPT 1.5.1.9
Server: CentOS 7
hasop
December 18, 2017 - 4:17 PM
Any ideas?
WAPT 1.5.1.9
Server: CentOS 7
December 18, 2017 - 8:40 PM
hasop wrote: ↑Dec 14, 2017 - 1:34 PM I tried installing again using wapdeploy and here's the complete result:
WAPT version:
Install ...
Cleanup...
The Wapttray simply creates a shortcut in:
c:\ProgramData\Microsoft\Windows\Start Menu\Programs\Startup\
which points to: c:\wapt\wapttray.exe
If you go to:
gpedit.msc
Then in:
Configuration Ordinateur -> Paramètres Windows -> Script -> Arrêt du system
If wapt exit does not appear, it did not work
https://www.wapt.fr/fr/doc/Frequent-pro ... -lance-pas
Could the problem causing the absence of a notification icon also prevent waptexit from running?
It doesn't work the same way, so no.
I'm going to test the wapttray with waptdeploy; it's been a long time since I've tested it
hasop
December 19, 2017 - 10:32
After checking, everything is OK (start menu and script stopped).
The notification icon only appears after restarting the computer.
I think the error message is preventing the icon from displaying during installation.
Thank you for your help.
WAPT 1.5.1.9
Server: CentOS 7
