WAPT 1.3 to 1.5 Migration Error
tech62
Registration: December 8, 2017 - 1:40 PM
December 22, 2017 - 5:44 PM
The package list is reappearing, everything looks OK :D (except for the console client).
I'm now going to tackle adding the repositories.
Thanks everyone for your help!
December 22, 2017 - 7:27 PM
tech62 wrote: Dec 22, 2017 - 5:29 PM I reread the documentation and created the missing group to update the database, but on the client side, I still don't see the list of available packages (it's empty).
From my console (version 1.5.11), when I generate the agent, everything goes smoothly. So I go to the portal to download the agent, and that's where the problem starts: it shows version 1.3.11. :shock:
CTRL F5?
tech62 wrote: Dec 22, 2017 - 5:29 PM A simple clarification, but one that will surely help some:
I noticed that wapt doesn't install/download on demand, let me explain.
Basically, you have to create a group containing the software via the console, assign this group to the machine(s) which, after the package update, will download all the components of this group.
Then, the user, by going to localhost:8088 via the web browser, will only be able to trigger the installation if they have been added to the SYSTEM group "waptselfservice", which must first be created on the client.
When the user requests the installation, they simply need to enter their usual login credentials to authorize it.
Yes, that's normal behavior; there's also waptexit or forcing installations from the console.
To see the fundamental principles:
https://www.wapt.fr/wapt-1.5/Theorique/ ... ndamentaux
