[SOLVED] Waptstarter?
Share your experience and thoughts about WAPT here / Come here and talk about your experience with Wapt, your opinion and your wishes
* French community support is provided on this forum
* Specify the installed WAPT version (1.8.2 / 2.0 / 2.1 / 2.2 / etc.) AS WELL AS the Enterprise / Discovery edition.
* Specify the server OS (Linux / Windows) and version (Debian Stretch/Buster - CentOS 7 - Windows Server 2012/2016/2019).
* Specify the OS of the administration/package creation machine (Windows 7 / 10)
. * As with any community forum, support is provided voluntarily by members. If you require sales support, you can contact the Tranquil IT sales department at 02.40.97.57.55
olaplanche
Registration: January 26, 2017 - 11:11
December 31, 2017 - 5:28 PM
I'm not sure where to ask my question, but I've been using Waptstarter 1.3.13.0 personally for a while now, and for the past few weeks, the updates haven't been working.
I'm using the repository https://wapt.lesfourmisduweb.org/wapt/ , which apparently now includes a manifest.sha256 file in each package. Waptstarter, however, is still looking for the manifest.sha1 file, which it obviously can't find!
Is there anything I can do about it? Is an update planned?
Thank you and happy holidays! :)
- Installed WAPT version: 2.6.0.16795 Enterprise
- Server OS: Linux / Debian Bookworm
December 31, 2017 - 5:46 PM
it's true that I no longer sign using SHA1 since I've already upgraded to version 1.5.
Otherwise, I can only advise you to use version 1.5; the starter version is already prepared.
Important: you must copy the last key to the %programfiles%\wapt\ssl directory:
https://wapt.lesfourmisduweb.org/wapt/ssl/
https://wapt.tranquil.it/wapt/nightly/w ... tarter.exe
olaplanche
December 31, 2017 - 7:27 PM
Great, I just installed v1.5 and the updates are working again :)
However, the Wapt service status page tells me:
 Statut WAPT
    Version de wapt-get.exe: 1.3.13.0
    Version de wapt-get.py: 1.5.1.12
Is this normal?
olaplanche
April 7, 2018 - 9:39 AM
I'm revisiting this issue because since the latest 1.5 updates, WaptStarter no longer works for me.
Trend Micro Internet Security detects the waptconsole.exe file as a virus in version 1.5.1.23.
If I install version 1.5.1.21 with the default options, there's no problem, except that I don't see any packages on the page http://127.0.0.1:8088/list.
I tested with another repository (lesfourmisduweb), same problem.
I can't figure out where the problem could be.
Does anyone have any ideas?
Thanks
April 7, 2018 - 11:05 AM
olaplanche wrote: Apr 7, 2018 - 9:39 AM Hello,
I'm revisiting this question because since the latest 1.5 updates, waptstarter no longer works for me.
If I install version 1.5.1.21 with the default options, there's no problem except that I don't see any packages on the page http://127.0.0.1:8088/list
. I tested with another repository (lesfourmisduweb), same problem.
I don't see where the problem could be.
Thanks
waptconsole is not useful in waptstarter; however, it remains to be seen if Trend Micro also detects nssm.exe...
what does one
wapt-get update -f
olaplanche
April 8, 2018 - 12:39
Here is the result of the command:
About to speak to waptservice...
Mise à jour de la liste des paquets disponibles
EWaptMissingCertificate: Public certificate C:\Program Files (x86)\wapt\private\31720980-D7DA-11DD-8DEA-2C4D54E5A194.crt not found
April 8, 2018 - 5:55 PM
Can you run it in an administrator command prompt?
olaplanche
April 8, 2018 - 6:10 PM
Here is the result in an administrator console:
Update package list
FATAL ERROR : EWaptMissingCertificate: Public certificate C:\Program Files (x86)\wapt\private\31720980-D7DA-11DD-8DEA-2C4D54E5A194.crt not found
April 8, 2018 - 11:38 PM
Yes, it's a bug,
we'll fix it quickly. ;)
olaplanche
April 9, 2018 - 9:07 AM
Ah great, thank you for your quick response!
