[RESOLVED] Hide system tray icon
Empbilly
Registration: January 15, 2018 - 8:59 PM
January 15, 2018 - 9:06 PM
How can I hide the "system tray icon" from "wapt client"?
I'm doing deploy via script and removed the "autorunTray" option, but it did not work.
January 16, 2018 - 8:52 AM
Hello
A package in the TIS repository can do that.
https://wapt.tranquil.it/package_detail ... 7_all.wapt
January 16, 2018 - 09:15
Hi Empbilly,
empbilly wrote: Jan 15, 2018 - 9:06 p.m. Hello,
Just to add some explanation to Simon's answer: the autorunTray parameter in waptdeploy add a link in user session's startup folder to start wapttray at logon. However if you don't mention that parameter, it won't do anything (neither add or remove). So if you have already started deploying with Wapttray option enabled, then you'll have to use the wapt package to remove it like Simon was saying.
Cheers,
Empbilly
January 16, 2018 - 11:17
dcardon wrote: Hi Empbilly,
Cheers,
sfonteneau wrote: Jan 16, 2018 - 08:52 Hello
Hello Simon and Denis, thanks for the help!!
So I need to modify the setup.py file that is in C:\wapt\waptupgrade\setup.py or download tis-notray_7_all.wapt and put it somewhere?
January 16, 2018 - 12:21
In WaptConsole, you go in the "Software Repository" tab, then click on "import from internet", then search for "tis-notray" package and click "import".
Then in the Inventory tab, you select the computer that needs wapttray to be removed, and you add that package to those computer.
Actually a WAPT software package can be either software OR configuration deployment. In the case of tis-notray package, it is just configuration deployment.
cheers,
Empbilly
January 16, 2018 - 12:45
dcardon wrote: Jan 16, 2018 - 12:21 In WaptConsole, you go in the "Software Repository" tab, then click on "import from internet", then search for "tis-notray" package and click "import".
cheers,
Thanks for the quick help Denis!!!
I was on the right track! :D
It only needed to attach the package to the computer.
