I'm very bad at programming and unable to create this package, so I'm turning to you to ask if you might have a package to install Avira antivirus.
Thank you.
[SOLVED] AVIRA Antivirus Package
- WAPT Expert
For the free part:
print('installing smp-avira')
install_exe_if_needed("avira_fr_av_5a66487bc3768__ws.exe",'/s',key='{E3F659C3-7936-4321-B886-4DA527DA72FE}',min_version='1.2.103.26908')Hello,
thank you so much, it's installing. I noticed a simple difference compared to my old script: I had used "/VERYSILENT" instead of /s. What does this "/s" mean and why is it working now?
And where do you find the "key"?
Thank you.
Thank you.
- WAPT Expert
For the uninstallkey:
https://www.wapt.fr/fr/doc/Utilisation/ ... t-registry
Regarding the /sa option, I don't know about replacing /verysilent.
I only tried with /VERYSILENT and saw that it didn't work.
I searched a bit online and saw that it worked with /s.
The executable has most likely changed in the meantime.
