[RESOLVED] Uninstall legacy software from machine
Empbilly
Registration: January 15, 2018 - 8:59 PM
January 22, 2018 - 6:29 PM
Hello wapters,
I wonder if with wapt I can uninstall a software that was already on the computer before installing the client?
January 22, 2018 - 8:29 PM
Yes, here is a sample code:
https://www.wapt.fr/en/doc/CreationPaqu ... -logiciels
for soft in installed_softwares('winscp3'):
Empbilly
January 22, 2018 - 9:04 PM
sfonteneau wrote: ↑January 22, 2018 - 8:29 PM Yes, here is a sample code:
Sorry for the question, but I run this code in some place or save this as a wapt package and link to the computer or none of this?
January 22, 2018 - 9:18 PM
As you said, you need to create a wapt package that will uninstall the software.
Empbilly
January 22, 2018 - 9:48 PM
sfonteneau wrote: ↑Jan 22, 2018 - 9:18 p.m. As you said, you need to create a wapt package that will uninstall the software.
Okay. Like this?
setup.py
uninstallkey=[]
    softname = 'firefox'
    check_installed_soft = installed_softwares(softname)
    if check_installed_soft:
                key=uninstall['1233A4A7-BA0B-4067-BE21-FB97AFABC0CF']
                if installed_softwares(uninstallkey=key):
                         run(WAPT.uninstall_cmd(uninstall['key']))
January 22, 2018 - 10:00 PM
Your code works. I propose to simplify it:
    if uninstall_key_exists('1233A4A7-BA0B-4067-BE21-FB97AFABC0CF'):
        run(WAPT.uninstall_cmd('1233A4A7-BA0B-4067-BE21-FB97AFABC0CF'))
Empbilly
January 23, 2018 - 12:25
sfonteneau wrote: ↑January 22, 2018 - 10:00 PM Your code works. I propose to simplify it:
sfonteneau,
This "key" is the value found in the column "Uninstall key" from Software Inventory in wapt console, right?
January 23, 2018 - 12:41
empbilly wrote: ↑Jan 23, 2018 - 12:25 This "key" is the value found in the column "Uninstall key" from Software Inventory in wapt console, right?
Yes!
you can also find the uninstallkey with this command: https://www.wapt.fr/en/doc/Utilisation/ ... t-registry
The second code I provided you can uninstall software that has the uninstall key "'1233A4A7-BA0B-4067-BE21-FB97AFABC0CF'"
This code bellow allows you to uninstall all the software that uses the word "winscp" in the information of their uninstall key.
Empbilly
January 23, 2018 - 1:35 PM
sfonteneau wrote: ↑January 23, 2018 - 12:41
Yes!
Now works!!! Thanks for the help sfonteneau!!! :)
The code for uninstalling only with the key, not worked, but with the code above, works like a charm!
In the end, the code is like:
uninstallkey=[]
	for soft in installed_softwares('old_version_of_firefox'):
For new users, remember to create or copy the "control" and "wapt.psproj" files and place them inside the "WAPT" folder in the package root, ie along with the "setup.py" file.
After that, you need to build the package with the below command:
wapt-get build-package <path of the files>
i.e.:
wapt-get build-package c:\waptdev\test-remove-firefox
