[SOLVED] Using the pyad module
January 26, 2018 - 4:43 PM
admin-style wrote: January 26, 2018 - 11:04 AM Hello everyone,
I manage three fairly large IT infrastructures and I recently adopted WAPT.
I'm quite happy with it and thank the people working on this project as well as the WAPT community.
I have a package that requires the use of the pyad module (a module that allows querying and manipulating Active Directory objects) in addition to installing the FusionInventory software.
I wanted to know how to use this module?
- I saw in a post that it was possible to use modules that can be copied into the WAPT package, but there's no documentation or example.
Could you please specify which version you used (see Alexandre's post)? viewtopic.php?f=9&t=886). THANKS.
WAPT 1.3: you should be able to include the library by putting it in the root of the package.
WAPT 1.5: the library is included natively
admin-style
Registration: January 26, 2018 - 10:57
January 29, 2018 - 3:29 PM
Hello, regarding server information and other details, here is the data:
WAPT Server version: 1.3.13.0
WAPT Agent version: 1.3.13.0
WAPT Setup version: 1.3.13.0
WAPT Deploy version: 1.3.13.0
Server is running Linux
, and the machine for the packages is running Windows 7.
admin-style
January 30, 2018 - 2:45 PM
when I place the library in the root directory of the WAPT package and run the installer, I get the following error:
FATAL ERROR: ImportError: No module named builtins
File "C:\wapt\wapt-get.py", line 1109, in
main()
File "C:\wapt\wapt-get.py", line 373, in main
res = mywapt.install_wapt(fn,params_dict = params_dict)
File "C:\wapt\common.py", line 3630, in install_wapt
raise e
admin-style
January 31, 2018 - 4:29 PM
is there a tutorial explaining how to use the Python module in WAPT packages?
admin-style
February 2, 2018 - 9:47 AM
has anyone ever needed to use a module other than those offered by Wapt?
If so, could you show me?
agauvrit
Registration: Nov 17, 2016 - 10:25
February 2, 2018 - 6:32 PM
  • WAPT 1.3: As explained above, by importing the library to the root of your package or into the site-package folder you will be able to use the pyad library during installation (https://pypi.python.org/pypi/pyad)
  • WAPT 1.5: The library is included in the WAPT installation and is therefore directly usable
Example of functional code:
import pyad.adquery
    print('installing tis-adtest')
    q = pyad.adquery.ADQuery()
    q.execute_query(
        attributes = ["distinguishedName", "description"],
        where_clause = "objectClass = '*'",
        base_dn = "OU=computers, DC=domain, DC=lan"
    for row in q.get_results():
        print row["distinguishedName"]
Alexander
admin-style
February 7, 2018 - 11:13
By following the example, I was able to install the package on the machine I use to create packages
Here is my code:
from pyad import *
    print('installation fusioninventory-agent')
    #Initialisations diverses
    ServerFusion = "http://adresse serveur fusion"
    idLycee=138
    #Recup nom ordinateur et chemin LDAP
    ComputerName = get_computername()
    ComputerLDAP = pyad.adsearch.by_cn(ComputerName)
    #Transformation pour extraction de l'OU
    ComputerTab = ComputerLDAP.split(",")
    ComputerExtract = ComputerTab[1].split("=")
    ComputerOU = ComputerExtract[1]
    tag = "%s;%s" % (idLycee,ComputerOU)
    print tag
    #Lancement de la commande install silencieuse
    if iswin64() :
        run(r'"fusioninventory-agent_windows-x64_2.3.21.exe" /acceptlicense /runnow /tag="%s" /server="%s" /S' % (tag, ServerFusion))
However, if I deploy it on a client machine, I get the error
Client workstation log:
2018-02-07 11:16:45,677 CRITICAL Error importing c:\windows\temp\waptbsr9b4\setup.py :
  File "c:\wapt\common.py", line 795, in import_setup
  File "c:\windows\temp\waptbsr9b4\setup.py", line 3, in <module>
    from pyad import *
  File "c:\windows\temp\waptbsr9b4\pyad\__init__.py", line 2, in <module>
    from .adbase import set_defaults as pyad_setdefaults
  File "c:\windows\temp\waptbsr9b4\pyad\adbase.py", line 3, in <module>
    from builtins import object
2018-02-07 11:16:46,019 CRITICAL Package claret-fusioninventory not installed due to errors : ImportError: No module named builtins
2018-02-07 11:16:46,019 CRITICAL Exception: Error during install of claret-fusioninventory: errors in packages [[u'claret-fusioninventory', PackageEntry('claret-fusioninventory','2.3.21-2')]]
Thank you for the example of the given code
