[Resolved] Problem with the registry
dsp
Registration: February 27, 2018 - 09:15
February 27, 2018 - 09:19
I have a small problem; when I try to modify the HKEY_CURRENT_USER For example:
registry_setstring(HKEY_CURRENT_USER,r'Software\Microsoft\Windows\CurrentVersion\Internet Settings','toto1','tata1')
The Wapt agent on the other machine makes the change in the HKEY_USERS.
Did I do something wrong?
Sincerely
WAPT version: 1.8.2
Server OS: Debian 10
Administration/package creation machine OS: Windows 10 1909
agauvrit
Registration: Nov 17, 2016 - 10:25
February 27, 2018 - 09:48
This is what is called a context problem.
The beehive HKEY_CURRENT_USER refers to the current user context, therefore during package installation (function install() ), this refers to the local SYSTEM user of the machine.
During your tests, this must have worked very well since the modifications are made in the hive of the user account used for package development.
But once the package is pushed to the workstations, the changes are not made in the user hives.
If you need to make changes to the user hive, you should therefore execute the function within the user customization context by defining the function session_setup():
def session_setup():
The documentation on this subject: https://www.wapt.fr/fr/doc-1.5/Creation ... index.html
Alexander
dsp
February 27, 2018 - 10:20
Thanks for your quick reply, it works better when things are done correctly ^^
WAPT version: 1.8.2
