I have a question regarding the terminal description field on the server. (attached file)
Since we have many terminals, I would like to define a custom description for each terminal where I install the WAPT agent.
How can I define this description on the terminal agent?
THANKS!
A+
Ioan
Terminal description
- WAPT Expert
with WAPT 1.5 you just need to press F2 to edit the job description and modify it on the remote job (only works if the job is connected)
