[RESOLVED] Mass uninstall not working
Empbilly
Registration: January 15, 2018 - 8:59 PM
March 5, 2018 - 12:55
If I was not mistaken in version 1.3 when I selected multiple hosts and selected the option "Remove package from hosts dependencies" the software was uninstalled automatically. Now from version 1.5 to uninstall I need to do this and also need to uninstall by the Overview tab.
Am I doing something wrong?
Empbilly
March 5, 2018 - 1:40 PM
I ended up doing more testing and now I have seen that by removing the software from the host dependency and also removing from the Overview tab, with all of them selected, mass uninstallation is done.
Thank you! :D
March 5, 2018 - 2:02 PM
Hi,
In Wapt (1.3 or 1.5, it is the same), adding a package to the dependencies of a machine actually trigger the install at the next upgrade.
But, removing a dependency (as you did with mass update actions), does not trigger the removal of the package.
You have to explicitly remove it (remotely like you did... ;) ) or add the package to the conflicting packages of the host (but this can result to complex depends/conflicts graphs...)
Hubert
