Wapt is not deployed via GPO
March 5, 2018 - 11:20
shlomi wrote: ↑March 5, 2018 - 11:18 What do you mean by loaded? I took the executable and copied it into the sysvol folder, then when it asks me for the script, I click browse and select my executable.
gpresult?
shlomi
Registration: February 17, 2017 - 8:47 AM
March 5, 2018 - 12:16
shlomi
March 5, 2018 - 5:02 PM
When I manually launch the waptdeploy executable, I get this message:
March 7, 2018 - 10:52
Hello Shlomi,
shlomi wrote: ↑March 5, 2018 - 5:02 p.m.Capture.PNG
In recent versions of WAPT, it is mandatory to provide the hash of the waptagent.exe file as a parameter to the waptdeploy executable:
https://www.wapt.fr/fr/doc/Installation ... -arguments
shlomi
March 7, 2018 - 2:19 PM
Hello dcardon,
Yes, I did see that part of the documentation and added that argument to the GPO settings.
Regards.
March 7, 2018 - 2:44 PM
Hello Shlomi,
shlomi wrote: ↑March 7, 2018 - 2:19 PM Yes, I did see that part of the documentation and added that argument to the GPO settings.
And what about the "--waptsetupurl" argument? It seems your repository isn't called wapt.groupe-lpf.com, and waptdeploy doesn't know where to find it.
shlomi
March 7, 2018 - 2:49 PM
Yes, I added it correctly with my server address.
shlomi
March 7, 2018 - 2:58 PM
Indeed, my repository is not named wapt.groupe-lpf.com.
How can I change it, as I am entering the correct address in the arguments?
Sincerely
March 7, 2018 - 3:29 PM
Add the following to the end of the arguments:
--waptsetupurl=http://mywapt.mydomain.lan/wapt/waptagent.exe
shlomi
March 7, 2018 - 4:39 PM
That's exactly what I did :s
