OCX Registration
Idaho
Registration: March 8, 2018 - 9:15 AM
March 8, 2018 - 09:47
Hello everyone,
I installed WAPT in my company environment to install software remotely, I'm quite satisfied. My goal is to create packages for all the software we use; however, there are many and some are very poorly packaged. I'm currently preparing a package for SRIM 2013 ( http://www.srim.org/SRIM/SRIMLEGL.htm The software doesn't have an installer, but it still requires registering OCX files, installing DLLs, and a font to function correctly. I've found solutions for the font and DLLs, but registering the OCX files—I don't know why—doesn't work with the command `Regsvr32 /s`. So I'm posting here to see if anyone else has encountered the same problem registering OCX files and if they have a solution. My software launches, but some functions refuse to run because the OCX files aren't present
- Installed WAPT version 1.3.13
- Server OS: Linux Debian 9
- Operating system of the administration/package creation machine: Windows 7
I'm testing the following code which isn't working. I've correctly placed the OCX files in the root directory of the package, and I also previously tested the Regsvr32 command on its own without success. :/
r# -*- coding: utf-8 -*-
targetdir = makepath(programfiles64,'SRIM 2013')
exename = 'SRIM.exe'
    print('installing pgip-srim2013')
    run(r'install.cmd')
    run(r'IF EXIST C:\Windows\SysWOW64 (C:\Windows\SysWOW64\regsvr32.exe /S COMCTL32.OCX) ELSE (C:\Windows\System32\regsvr32.exe  /S COMCTL32.OCX)')
    run(r'IF EXIST C:\Windows\SysWOW64 (C:\Windows\SysWOW64\regsvr32.exe /S COMDLG32.OCX) ELSE (C:\Windows\System32\regsvr32.exe /S COMDLG32.OCX)')
    run(r'IF EXIST C:\Windows\SysWOW64 (C:\Windows\SysWOW64\regsvr32.exe /S MSFLXGRD.OCX) ELSE (C:\Windows\System32\regsvr32.exe /S MSFLXGRD.OCX)')
    run(r'IF EXIST C:\Windows\SysWOW64 (C:\Windows\SysWOW64\regsvr32.exe /S TABCTL32.OCX) ELSE (C:\Windows\System32\regsvr32.exe /S TABCTL32.OCX)')
    run (r'IF EXIST C:\Windows\SysWOW64 (C:\Windows\SysWOW64\regsvr32.exe /S  RICHTX32.OCX) ELSE (C:\Windows\System32\regsvr32.exe /S RICHTX32.OCX)')
    register_windows_uninstall(control)
    print('uninstalling pgip-srim2013')
    killalltasks(exename)
    killalltasks('SR.exe')
    if isdir(targetdir):
        remove_tree(targetdir)
    remove_file(r'C:\ProgramData\Microsoft\Windows\Start Menu\Programs\SRIM 2013.lnk')
    unregister_uninstall('pgip-srim2013')
The code for the installation script (if I'm creating a shortcut myself and not using the function provided by WAPT, it's because I was getting an error when launching the software that I don't encounter when doing it this way; I don't really understand why, actually):
@ECHO OFF
ECHO INSTALLING SRIM 2013
xcopy SRIM_2013 "C:\Program Files\SRIM 2013" /S /I
CLS
xcopy "SRIM 2013.lnk" "C:\ProgramData\Microsoft\Windows\Start Menu\Programs" /S /I
CLS
ECHO ADDING FONTS
addfonts.cmd
CLS
ECHO DONE
The code for the font addition script that I found online basically scans the directory and silently adds the font files it contains (it's a shame the same thing doesn't exist for those darn OCX files). I'm posting it here mainly because it might help some people who want to create packages to install fonts:
REM http://www.msfn.org/board/topic/119612-how-to-install-a-font-via-the-command-line/
@ECHO OFF
TITLE Adding Fonts..
REM Filename: ADD_Fonts.cmd
REM Script to ADD TrueType and OpenType Fonts for Windows
REM By Islam Adel
REM 2012-01-16
REM How to use:
REM Place the batch file inside the folder of the font files OR:
REM Optional Add source folder as parameter with ending backslash and dont use quotes, spaces are allowed
REM example "ADD_fonts.cmd" C:\Folder 1\Folder 2\
IF NOT "%*"=="" SET SRC=%*
ECHO.
ECHO Adding Fonts..
ECHO.
FOR /F %%i in ('dir /b "%SRC%*.*tf"') DO CALL :FONT %%i
REM OPTIONAL REBOOT
REM shutdown -r -f -t 10 -c "Reboot required for Fonts installation"
ECHO.
ECHO Done!
EXIT
:FONT
ECHO.
REM ECHO FILE=%~f1
SET FFILE=%~n1%~x1
SET FNAME=%~n1
SET FNAME=%FNAME:-= %
IF "%~x1"==".otf" SET FTYPE=(OpenType)
IF "%~x1"==".ttf" SET FTYPE=(TrueType)
ECHO FILE=%FFILE%
ECHO NAME=%FNAME%
ECHO TYPE=%FTYPE%
COPY /Y "%SRC%%~n1%~x1" "%SystemRoot%\Fonts\"
reg add "HKLM\SOFTWARE\Microsoft\Windows NT\CurrentVersion\Fonts" /v "%FNAME% %FTYPE%" /t REG_SZ /d "%FFILE%" /f
GOTO :EOF
Finally, here is the content of the package directory:
 Répertoire de C:\waptdev\pgip-srim2013-wapt
08/03/2018  10:24    <REP>          .
08/03/2018  10:24    <REP>          ..
06/03/2018  15:53             1ÿ133 addfonts.cmd
23/05/2000  00:58           608ÿ448 ComCtl32.ocx
23/05/2000  00:58           140ÿ488 ComDlg32.ocx
08/03/2018  09:55               255 install.cmd
20/03/1996  06:00            80ÿ008 Linedraw.ttf
22/05/2000  22:58           244ÿ416 MSFlxGrd.ocx
09/03/2004  23:45           212ÿ240 RichTx32.ocx
07/03/2018  10:56             1ÿ322 setup.py
07/03/2018  10:57             1ÿ767 setup.pyc
06/03/2018  16:58             1ÿ331 SRIM 2013.lnk
06/03/2018  14:28    <REP>          SRIM_2013
30/08/2001  22:43           209ÿ192 TabCtl32.ocx
07/03/2018  08:48    <REP>          WAPT
              11 fichier(s)        1ÿ500ÿ600 octets
               4 R‚p(s)   1ÿ215ÿ844ÿ352 octets libres
Thank you in advance for your answers :)
March 9, 2018 - 4:47 PM
The problem is most likely related to the automatic rewriting of system paths by Windows in the case of a 32-bit app on a 64-bit Windows system.
WAPT is 32-bit, so by default Windows presents a 32-bit "view" of the system.
To disable the redirection, you need to use the context helper
disable_file_system_redirection
    with disable_file_system_redirection():
        run(r'...')
To register OCX files, the setuphelpers register_dll() function must work
import winshell
    filecopyto('MY.OCX',makepath(winshell.get_folder_by_name('SYSTEMX86'),'MY.OCX'))
    register_dll(makepath(winshell.get_folder_by_name('SYSTEMX86'),'MY.OCX'))
