[SOLVED] Transition 1.3.12.13 -> 1.5.21
Imp83
Registration: February 19, 2018 - 12:07
March 14, 2018 - 2:52 PM
before upgrading to version 1.5, it's mandatory to update the agents to version 1.3.13.0. However, in my network, I've been a bit late, and 90% of the workstations are still on version 1.3.12.13. I've just updated WaptUpgrade to 1.3.13.0.
If I continue with version 1.5, will the machines still on 1.3.12.13 be upgraded to 1.3.13 before updating to 1.5, or will they update directly to the latest version, which wouldn't work?
March 14, 2018 - 2:57 PM
To be precise,
if you want the waptupgrade package to work, the entire network must be on version 1.3.13.0.
Otherwise, you will need to push the installation of the new agent using waptdeploy via GPO or IPC. (
Simon)
Imp83
March 14, 2018 - 3:19 PM
Thank you so much for your quick reply! I'll wait a few more days for version 1.5 then :cry:
