Clock icon on machine - v 1.5.1.21
vertrin
Registration: March 14, 2018 - 11:25
March 16, 2018 - 11:05
Hello
, when adding machines, they appear with a clock icon instead of the green dot?
As a result, I can't use the "Check for updates" and "Start installations" buttons,
even though the agent is running correctly on the machine and I can force the update from there.
Fred
agauvrit
Registration: Nov 17, 2016 - 10:25
March 16, 2018 - 11:41
This problem is very often related to an NTP server/time issue on the workstation.
With WAPT 1.5, the client-server connection is made via a secure HTTPS connection, so the workstation's clock setting is important and should not exceed 5 minutes.
Please verify that your workstations have the correct time; if necessary, push a packet to force the NTP server settings.
Regards,
Alexandre
vertrin
March 16, 2018 - 12:56
Argh! Everything's okay!
That's a silly thing. :o
Thanks for the quick reply!
March 16, 2018 - 6:46 PM
I invite you to look at the signature_clockskew parameter ;) :
https://www.wapt.fr/fr/doc/Configuratio ... tie-option
