[RESOLVED] wapt console via webGui
Empbilly
Registration: January 15, 2018 - 8:59 PM
March 22, 2018 - 12:24
Hi folks,
Is there any idea of ​​wapt having a wapt console via webgui?
It would be amazing! :D
March 22, 2018 - 12:39
For what use do you need a web console?
Empbilly
March 22, 2018 - 12:50
sfonteneau wrote: March 22, 2018 - 12:39 For what use do you need a web console?
Centralized management!
March 22, 2018 - 2:49 PM
Today, wapt can be launched from multiple console at the same time.
Each administrator can launch the console from his station.
Empbilly
March 22, 2018 - 3:31 PM
sfonteneau wrote: March 22, 2018 - 2:49 p.m. Today, wapt can be launched from multiple console at the same time.
Yes, we have already done so, but since we use linux, we need to have a VM for this. Not that a VM is the problem, but if it had a webgui, it would be more organized and better to manage. :D
March 22, 2018 - 6:00 PM
wapt works fine under winehq:
https://www.winehq.org/
During installation, you must uncheck the installation of the service.
Empbilly
March 22, 2018 - 7:07 PM
sfonteneau wrote: March 22, 2018 - 6:00 p.m. wapt works fine under winehq:
Okay. I installed via playonlinux. Works! :D
vcardon
March 22, 2018 - 11:32 PM
Happiness for all admins, that's the goal of WAPT ;)
Happiness for you first, then you can tell you friends.
Vincent
Empbilly
March 23, 2018 - 2:56 PM
Vincent CARDON wrote: March 22, 2018 - 11:32 p.m. Happiness for all admins, that's the goal of WAPT ;)
Vincent
Thanks Vincent!!! :D
