Empty package to uninstall an application
benoitpatin
Registration: February 21, 2018 - 5:05 PM
March 22, 2018 - 09:44
- Installed WAPT version: 1.5.1.18 Community
- Linux Debian 9 server OS
- Operating system of the administration/package creation machine: Windows 10
I would like to create a source-free package with just one command to uninstall a program on my computers.
I do not have the original source code for the application.
Using the command wapt-get list-registry software_name I am able to retrieve the Uninstallstring and the uninstallkey on a target machine.
So I foolishly created an empty package with the given information:
uninstallkey = ['Foxit Reader_is1']
    print('uninstalling Foxit Reader')
    run(r'"C:\Program Files (x86)\Foxit Software\Foxit Reader\unins000.exe"')
But it doesn't seem to be working properly. Since this is my second package, I think I'm missing a couple of things to get it right.
Is there anyone who can help me?
THANKS
agauvrit
Registration: Nov 17, 2016 - 10:25
March 22, 2018 - 10:03
Hello Benoît,
The function uninstall This allows you to uninstall software deployed with WAPT. If you want to uninstall software directly, you must write this code in the function install from the package.
If you want to uninstall software in all possible versions, it's best to use a function like this:
    for soft in installed_softwares('Foxit Reader'):
        if Version(soft['version']) < Version('18'):
benoitpatin
March 22, 2018 - 2:17 PM
Great, the quick response! :D
However, I need some clarification...
The word "version" between a single quote and a bracket should correspond to the version in my Add/Remove Programs?
What should the word "key" between a single quote and a square bracket correspond to? The uninstallkey or the uninstallstring?
March 22, 2018 - 2:46 PM
benoitpatin wrote: ↑March 22, 2018 - 2:17 PM Does the word "version" between a single quote and a bracket refer to the version in my Add/Remove Programs?
Yes
benoitpatin wrote: ↑March 22, 2018 - 2:17 PM What should the word "key" between a single quote and a square bracket refer to? The uninstallkey or the uninstallstring?
The word 'key' should not be replaced; we will retrieve the 'key' value from the `uninstallkey` currently being tested
benoitpatin
March 22, 2018 - 2:57 PM
Okay, great, here is min setup.py:
        if Version(soft['version']) < Version('8.2.1.6871'):
I build, I upload, I launch the package on my machine but nothing happens.
I haven't made any mistakes anywhere. Did I miss something?
March 22, 2018 - 3:17 PM
I don't see any errors in your code.
On the machine you are testing on.
Can you run a:
wapt-get list-registry Foxit
to see what happens
agauvrit
March 22, 2018 - 3:18 PM
To see the list of potentially affected software:
wapt-get list-registry Foxit Reader
If the software does not appear, it will not be uninstalled; you may need to use only "Foxit" as a search keyword
Alexander
benoitpatin
March 22, 2018 - 3:22 PM
UninstallKey                           Software                                                              Version             Uninstallstring
Foxit Reader_is1                       Foxit Reader                                                          8.2.1.6871          "C:\Program Files (x86)\Foxit Software\Foxit Reader\unins000.exe"
agauvrit
March 22, 2018 - 3:27 PM
the returned version is equal to the version imposed in the version test (8.2.1.6871) so it is not uninstalled.
To be more "brute forceful," you can write the complete uninstallation of all possible versions like this:
benoitpatin
March 22, 2018 - 5:32 PM
It's not working and I don't see any error message anywhere (at the same time, maybe there isn't one...an error!).
How can I troubleshoot?
