Complete Wapt update from 1.3 to 1.5 on Debian
agauvrit
Registration: Nov 17, 2016 - 10:25
March 22, 2018 - 3:24 PM
Are you trying to pull a Man in the Middle with your SonicWall? ;)
Try adding http:// to the URL, it should work better.
Alexandre
Anthony Jimenez
Registration: March 15, 2018 - 11:53
March 22, 2018 - 3:56 PM
Still nothing!
Same error!
Error: The certificate for "wapt.tranquil.it" is not trusted.
Error: The certificate for "wapt.tranquil.it" is not from a known issuer.
gpg: no valid OpenPGP data found.
Anthony Jimenez
March 22, 2018 - 4:11 PM
Things are moving along, the installation is going well now...
To be continued
. Thanks A.
Anthony Jimenez
March 22, 2018 - 4:44 PM
The Wapt server is installed.
I just entered the filename for my key, but I don't have the password for the private key.
How can I retrieve it?
March 22, 2018 - 5:25 PM
Hello Anthony,
Anthony JIMENEZ wrote: ↑March 22, 2018 - 4:44 PM The Wapt server is installed.
I just entered my key filename, but I don't have the private key password.
In version 1.3, by default there was no password on the private key (although the WAPT 1.3 environment already supported password-protected keys).
From version 1.5 onwards, the installer requires a password on the key for better security.
So if you are migrating from version 1.3 to 1.5, it is very likely that there is no password on the old key. However, you must set a password to generate the new key/certificate.
PS: If you are already using WAPT 1.5 and have lost the key password, you will need to generate a new certificate and re-upload it to all workstations. There is no way to recover the password.
Anthony Jimenez
March 27, 2018 - 09:01
the WAPT server is operational except that when I try to access my repository at https://myserver.com/wapt/
I get a 403 Forbidden error (nginx/1.10.3).
It's definitely an access problem, but which files need to have their access rights changed?
Thank you
