Good evening,
I've noticed an issue on two sites I manage with WAPT. For example, in one site with the server name https://wapt-srv.lmaccassin.loc,
when manually running waptdeploy, it doesn't point to that address but to https://wapt.
To work around this, I had to create a host named wapt (IP address 10.171.40.31) in my Windows Server 2012 R2 DNS, with an alias srv-wapt pointing to the host.
My question is: is the address hard-coded in waptdeploy? Because doing this allowed me to unlock the waptagent installation via GPO... Is it possible to have a feature that allows me to regenerate waptdeploy with the correct server parameters?
WAPT 1.5 deployed via GPO
- WAPT Expert
Good evening Joris,
waptdeploy --hash="43254648348435423486"--minversion=1.5.1.21 --waptsetupurl="http://srvwapt.mydomain.lan/wapt/waptagent.exe--wait=10
It is possible to pass the parameter to waptdeploy, cf https://www.wapt.fr/fr/doc/Configuratio ... waptdeployjoris.remandet wrote: ↑March 26, 2018 - 10:04 PM A question that comes to mind: is the address hard-coded in waptdeploy? Because doing that allowed me to unlock the waptagent installation via GPO... Is it possible to have a feature that allows regenerating waptdeploy with the correct server parameters?
joris.remandet
- Registration: January 16, 2018 - 6:29 PM
Okay, it works, but I'll have to find a solution. When waptdeploy is run, Trend Micro antivirus kicks in, removes waptagent.tmp, and stops waptagent from running... Even after excluding everything (both in scans and component monitoring)
