error 403 forbidden / nginx/1.10.3
Anthony Jimenez
Registration: March 15, 2018 - 11:53
March 27, 2018 - 11:45
I'm trying to connect to my repository server https://server.com/wapt but I'm getting a 403 Forbidden error.
Is this why I'm getting the following errors when I try to deploy the packages to a PC:
Exception: Error installing 907EBD9C-FBDC-11DF-A0DF-11D4B0F2B768 (=1): errors in packages [[u'907EBD9C-FBDC-11DF-A0DF-11D4B0F2B768 (=1)', PackageEntry('907EBD9C-FBDC-11DF-A0DF-11D4B0F2B768','1') ]]
Debian Stretch server in virtualized mode.
Administration console on a Windows 10 Pro 64-bit PC.
Thank you
, A. Jimenez
March 27, 2018 - 7:37 PM
The 403 error is normal on the /wapt/ part of the repository.
Regarding the error
Exception: Erreur lors de l'installation de 907EBD9C-FBDC-11DF-A0DF-11D4B0F2B768 (=1): erreurs dans les paquets [[u'907EBD9C-FBDC-11DF-A0DF-11D4B0F2B768 (=1)', PackageEntry('907EBD9C-FBDC-11DF-A0DF-11D4B0F2B768','1') ]]
You need to click on the post that is in error then click on the package in error "907EBD9C-FBDC-11DF-A0DF-11D4B0F2B768" and read the error on the bottom window.
