[SOLVED] Mongorestore restoration issue
Matthew
Registration: September 19, 2016 - 8:50 p.m.
April 5, 2018 - 10:59
Server: Debian Stretch x64
waptserveur 1.3.13.0
To migrate to version 1.5 of wapt I had to switch from ubuntu server 16.04 to debian stretch.
So I followed the procedure
https://www.wapt.fr/fr/doc/waptserver_u ... erver.html
Upon execution of the command
mongodump
I obtained a dump folder which I saved.
It contains an empty admin folder and a wapt folder with the following files:
hosts.bson hosts.metadata.json system.indexes.bson
I then backed up the packages as instructed and installed a clean version of the Debian server and then Wapt Server version 1.3.13.0
I restored the contents of the wapt and wapt-host folders in the www/ folder.
So far, everything has gone well.
I'm having a problem restoring the MongoDB database:
I go to the location where I saved the previously created dump folder and execute the command
mongorestore /root/wapt.dump
gives me the error
Failed: mongorestore target '/root/wapt.dump' invalid: stat /root/wapt.dump: no such file or directory
Is there an error in my procedure?
THANKS
Matthew
April 5, 2018 - 11:46
console 1.3.13.0 on Windows 10
I tried to navigate to the folder where my database had been saved, which contains the dump folder.
I launched the order
mongorestore dump/
A restoration appears to have been carried out with errors:
2018-04-05T11:34:04.880+0200    building a list of dbs and collections to restore from dump dir
2018-04-05T11:34:04.887+0200    reading metadata for wapt.hosts from dump/wapt/hosts.metadata.json
2018-04-05T11:34:04.914+0200    restoring wapt.hosts from dump/wapt/hosts.bson
2018-04-05T11:34:05.354+0200    error: multiple errors in bulk operation:
  - E11000 duplicate key error collection: wapt.hosts index: uuid_1 dup key: { : "CD00EF00-A21C-11E1-BD3B-AC162D06646F" }
And several other lines of the same type as the last one. Nothing catastrophic?
but when I launch the wapt console on the computer I do see all my computers present with their status (up to date, error, ...) and the list of packages installed on each machine but the private repository is empty.
Matthew
April 5, 2018 - 11:59
In the console I have an error on the repository but I cannot see the details of the error because the window cannot be enlarged.
I wonder if this isn't an ownership/access rights issue with the folder in www/
Currently I have this:
root@ltsp01:/var/www# ls -la
total 60
drwxr-xr-x  8 root root      4096 avril  4 12:05 .
drwxr-xr-x 12 root root      4096 avril  4 12:04 ..
drwxr-xr-x  2 root root      4096 avril  4 12:05 html
drwxr-xr-x  3 wapt root     20480 avril  5 10:23 wapt
drwxr-xr-x  2 wapt www-data  4096 avril  4 12:05 waptdev
drwxr-xr-x  2 wapt www-data  4096 avril  4 12:05 wapt-group
drwxr-xr-x  3 wapt root     16384 avril  5 10:30 wapt-host
drwxr-xr-x  2 wapt www-data  4096 avril  4 12:05 waptwua
Matthew
April 5, 2018 - 12:58
And there you have it:
A little tap
chown -R wapt:www-data /var/www/wapt/
chown -R wapt:www-data /var/www/wapt-host/
chown -R wapt:www-data /var/www/wapt-group/
then a scan of the directories
/usr/bin/python /opt/wapt/wapt-scanpackages.py /var/www/wapt/
/usr/bin/python /opt/wapt/wapt-scanpackages.py /var/www/wapt-host/
/usr/bin/python /opt/wapt/wapt-scanpackages.py /var/www/wapt-group/
Finally, a restart of services:
systemctl start waptserver
indicated in the section https://www.wapt.fr/fr/doc/waptserver_backup.html
And everything went back to normal for the migration from Ubuntu 16.04 to Debian Stretch.
I'm going to be able to start the update to Wapt server 1.5! :)
