I'm currently testing the WAPT server (Windows version) version 1.0
since February (following an article on Korben).
I just downloaded and installed the latest version, 1.1.1.0.
Is there a better way to update than installing over the old version?
I've generated a new version of the agent.
Is there a way to update the agent version installed on all existing clients
(is it essential to update the agents on the clients?)
Or do I need to generate a WAPT package of the new agent and deploy it to all my clients?
Thank you.
Wapt server and client update.
- Yvan Karmouta
- Registration: June 18, 2014 - 10:09
I have removed your duplicates; the problem originated with our forum, which we are currently updating.
We are happy to see that you like Wapt
To answer your question, there is documentation on Wapt upgrade.
In summary, updating on a Linux server is simpler
For a Windows server, you will need to download the new server EXE and restart the installation.
If you have a management position, you will need to update the WaptSetup on it.
For client workstations, following the documentation you will create a wapt package which will take care of updating the wapt agents.
Sincerely
apt-get update && apt-get upgradeIf you have a management position, you will need to update the WaptSetup on it.
Sincerely
Yvan Karmouta - Tranquil IT Systems
Feel free to leave us your opinion on Wapt in the forum, or to answer our questionnaires
