[SOLVED] Reachable or not reachable that is the question ;-)
CasseThor
Registration: December 1, 2017 - 9:25 PM
April 5, 2018 - 4:22 PM
I just installed version 1.5 without too much trouble.
I have a computer lab with a homogeneous set of machines, and I'm having an issue with some PCs that are unreachable,
even though it doesn't show "disconnected" on some of them (not all!).
As a result, I can't use the "Check for updates" and "Start installations" buttons.
If I connect to the client machines with a VNC client, and then shut them down, I do get the dialog box to install the software.
Could this be a bug?
I should mention that I installed the agent in this computer lab which already had version 1.3. Is it risky to do this?
Thank you for your answers
. Best regards.
CasseThor
April 5, 2018 - 4:26 PM
I tried completely uninstalling and then reinstalling the client, but to no avail
April 5, 2018 - 6:35 PM
A time discrepancy between the client and the server?
CasseThor
April 9, 2018 - 9:34 AM
Yes, that's right.
Thank you. :)
