[RESOLVED] Update to 1.5.1.23: database version
PPE
Registration: March 19, 2018 - 5:03 PM
April 12, 2018 - 4:57 PM
I just updated WAPT to version 1.5.1.23. I noticed that the web interface still shows a database version 1.5.1.22. (see attached image)
Have I missed something?
Thanks in advance.
Screenshot 2018-04-12 at 16:47:13.png
Screenshot 2018-04-12 at 16:47:13.png (16.67 KB) Viewed 5530 times
April 16, 2018 - 3:48 PM
Hello PPE,
PPE wrote: ↑Apr 12, 2018 - 4:57 PM I just updated WAPT to version 1.5.1.23. I noticed that the web interface still shows a database at version 1.5.1.22. (see attached image)
Thanks in advance.
There is no change to the basic schema with each minor version update. It's possible the schema version number wasn't updated during the version increment. I'll check with Hubert about that.
For your information, the WAPT server updates its PostgreSQL database schema at startup if it's necessary and if it has the required permissions (which is the case in a default installation). It's no longer necessary to do this manually.
PPE
April 17, 2018 - 4:17 PM
Okay, noted.
Thank you.
