When uploading a package containing spaces, I encountered an error:
HTTPError: 500 Server Error: for url: https://wapt-dev.domain.
com/api/v3/upload_packagesHere is the upload log in debug mode:
2018-04-19 11:27:16,134 INFO Configuration file : C:\Users\user\AppData\Local
\waptconsole\waptconsole.ini
2018-04-19 11:27:16,134 INFO waptserver : <WaptServer https://wapt-dev.
domain.com>
2018-04-19 11:27:16,134 INFO repositories : [<WaptRepo https://wapt-dev.c
osium.com/wapt for domain >]
2018-04-19 11:27:16,135 INFO packages count : 617
2018-04-19 11:27:16,135 DEBUG WAPT base directory : C:\Program Files (x86)\wapt
2018-04-19 11:27:16,135 DEBUG Package cache dir : C:\Users\user\AppData\Local
\waptconsole\cache
2018-04-19 11:27:16,135 DEBUG WAPT DB Structure version;: 20180303
Uploading packages to https://wapt-dev.domain.com
Please get login for https://wapt-dev.domain.com/api/v3/upload_xxx:admin
Password:
D:\git\wapt\software\SSH Daemon_7.6.1.1-5_all.wapt[
2018-04-19 11:27:23,467 DEBUG Starting new HTTPS connection (1): wapt-dev.cos
ium.com
D:\git\wapt\software\SSH Daemon_7.6.1.1-5_all.wapt[=============================
===] 4470/4470 - 00:00:00
FATAL ERROR : HTTPError: 500 Server Error: for url: https://wapt-dev.domain.
File "<string>", line 1215, in <module>
File "<string>", line 959, in main
File "C:\Program Files (x86)\wapt\common.py", line 2947, in upload_package
return self.http_upload_package(filenames,wapt_server_user=wapt_server_user,
wapt_server_passwd=wapt_server_passwd)
File "C:\Program Files (x86)\wapt\common.py", line 2920, in http_upload_packag
e
res_partiel = self.waptserver.post('api/v3/upload_packages',data=f.get(),aut
h=auth,timeout=300)
File "C:\Program Files (x86)\wapt\common.py", line 1606, in post
req.raise_for_status()
File "C:\Program Files (x86)\wapt\lib\site-packages\requests\models.py", line
935, in raise_for_status
raise HTTPError(http_error_msg, response=self)
requests.exceptions.HTTPError: 500 Server Error: for url: https://wapt-dev.c
osium.com/api/v3/upload_packages
Exception at 0043E08A: EPyIOError:
HTTPError: 500 Server Error: for url: https://wapt-dev.domain.com/api/v3/upl
oad_packages.
