Hello everyone,
I tried to download the Google Chrome package, but it seems to have a problem
(see attached file).
Are you experiencing the same issue? I'm using WAPT 1.3.5.0.
Thank you for your help.
Knpc
Google Chrome Package
- WAPT Expert
It's working fine on my end.
Perhaps the local cache needs clearing.
Otherwise, the sum after downloading is incorrect.
- Attachments
- clear cache.jpg (28.81 KB) Viewed 20106 times
thank you for your reply, but even after clearing the cache it still doesn't work, so I downloaded it directly from the website to put it in my dev folder and then imported it from a file to add it to my list.
I started the package installation, but it doesn't finish and I get the error shown in the attached file.
I can't download the one from La Fourmi because it requires the latest version of the WAPT server. Is the Chrome package different between different versions of the WAPT server?
Thank you,
Knpc
Thank you,
Knpc
- Attachments
- chrome error.png (14.96 KB) Viewed 20096 times
- WAPT Expert
A new version of the package is available.
If the problem persists, could you provide more information about the machine experiencing the problem? (OS?)
thank you for providing a new package, but I'm still having the same problem downloading it. For example, I try Flash Player, and the package downloads correctly.
With Chrome, I get the same MD5 error. Is it compatible with server version 1.3.5?
Knpc
Knpc
The new packages that Tranquil IT creates and those that the ants seem to be making available are designed for WAPT 1.5.
As a reminder, the packages we provide are intended to serve as inspiration. Tranquil IT is under no obligation to guarantee the suitability of these packages for your specific needs. A service offering certified packages is currently under consideration.
There is no backward compatibility between 1.5 and 1.3 and packages in 1.3 will not be maintained or updated in the medium and long term.
Your best option is to upgrade to version 1.5 Community or Enterprise. We've spent many days and weekends writing and testing the documentation so you can do it yourself, and Tranquil IT offers its services if you prefer a simpler approach.
Sincerely.
Vincent
I'm not commenting on the quality of Tranqui IT's services. My question was simply whether the package was compatible with version 1.3.5, which it isn't, and I understand perfectly well that packages for 1.5 are starting to be released.
I plan to migrate to this version soon, I hope.
Just one question: how can you distinguish a package for 1.3.5 from one for 1.5?
Thanks
, Knpc
Thanks
, Knpc
