Hello everyone,
I'm new to WAPT and I need your help.
I want to update Firefox ESR 52.7.2 to 52.7.3 on the network, but only if that version is already installed on the PC.
The `install_exe_if_needed` function doesn't meet my needs.
I have several PCs:
- Windows 7 32-bit with Firefox ESR 52.7.2 32-bit , which I would like to update to Firefox ESR 52.7.3 32-bit
- Windows 7 64-bit with Firefox ESR 52.7.2 32-bit (due to compatibility issues with some applications), which I would like to update to Firefox ESR 52.7.3 32-bit
- Windows 7 and 10 64-bit with Firefox ESR 52.7.2 64-bit , which I would like to update to Firefox ESR 52.7.3 64-bit.
How can I retrieve the version of Firefox ESR installed on the PC (which wasn't installed by wapt)? Is there a Python function that can retrieve this information?
How can I create this package in Python?
[SOLVED] Firefox ESR 32bit/64bit Update Package
- WAPT Expert
Please specify your WAPT version and server OS.
WAPT Server version: 1.5.1.23
WAPT Agent version: 1.5.1.23
WAPT Deploy version: 1.5.1.23
OS: Windows 2012 R2 64-bit
So, I managed to retrieve the Firefox version with:
for soft in installed_softwares('Firefox')Code: Select all
[{'install_date': '',
'install_location': u'C:\\Program Files\\Mozilla Firefox',
'key': u'Mozilla Firefox 52.7.2 ESR (x64 fr)',
'name': u'Mozilla Firefox 52.7.2 ESR (x64 fr)',
'publisher': u'Mozilla',
'system_component': 0,
'uninstall_string': u'"C:\\Program Files\\Mozilla Firefox\\uninstall\\helper.exe"',
'version': u'52.7.2'}]Code: Select all
for soft in installed_softwares('Firefox'):
nom_firefox = soft['name']
print(u"Le firefox installé est: %s" % nom_firefox)
installed_softwares('Firefox')[0]['name']
installed_software() returns a list (recognizable by the brackets), we take the first element hence the [0].
Each element of the list is a "dictionary" (recognizable by its representation with curly braces). The key "name" is extracted from this dictionary using ['name'].
Illustration:
print(installed_softwares('Firefox'))
print(installed_softwares('Firefox')[0])
print(installed_softwares('Firefox')[0]['name'])
