[SOLVED] Console crash
renaud.counhaye
Registration: December 13, 2017 - 11:45
April 26, 2018 - 9:52 AM
I have a small problem; after importing several files, my console now crashes when I go to the "Softwares repository" section
2018-04-26 09_48_33-WAPT console.png (5.32 KB) Viewed 15478 times
I then checked to see if I had a duplicate packet on the server, but it seems correct:
2018-04-26 09_50_24-Settings.png (31.89 KB) Viewed 15478 times
And when I try to rebuild the packet index via the .py file on the server:
rcounhaye@wapt $ /usr/bin/python /opt/wapt/wapt-scanpackages.py /var/www/wapt/
  File "/opt/wapt/wapt-scanpackages.py", line 32, in <module>
    from waptutils import __version__,setloglevel
  File "/opt/wapt/waptutils.py", line 41, in <module>
    import requests
ImportError: No module named requests
[ /var/www ]
rcounhaye@wapt $ sudo /usr/bin/python /opt/wapt/wapt-scanpackages.py /opt/websites/wapt/
    import requests
In short, it had to happen to me D:
WAPT 1.5 server on Debian 9
Windows 10 PC Admin.
Renaud Counhaye,
Network Systems Technician,
Central Functions Division
, Ymagis Group
April 26, 2018 - 12:00
And like this?
wapt-scanpackages /var/www/wapt/
renaud.counhaye
April 26, 2018 - 4:14 PM
Hm, well
rcounhaye@wapt $ sudo wapt-scanpackages /var/www/wapt/
I haven't received any feedback, is that normal?
Oh, and it looks like I've crashed my server now :/ I'm really bad at this :( (502 bad gateway even on the console)
Renaud Counhaye,
, Ymagis Group
April 26, 2018 - 4:21 PM
For more information:
wapt-scanpackages -ldebug /var/www/wapt
To force a rescan of all packets:
wapt-scanpackages -f /var/www/wapt
502 bad gateway error: the waptserver service is stopped.
systemctl stop waptserver
systemctl start waptserver
systemctl status waptserver
A 502 status code can sometimes be "negatively cached" in the reverse proxy (nginx)
To be sure:
systemctl restart nginx
renaud.counhaye
April 26, 2018 - 5:08 PM
Ah great, the -ldebug command does display the scan correctly :)
However, you are right, the server is down, and it won't start:
rcounhaye@wapt $ sudo systemctl status waptserver
● waptserver.service - WAPT Server startup script
   Loaded: loaded (/usr/lib/systemd/system/waptserver.service; enabled; vendor preset: enabled)
   Active: failed (Result: exit-code) since Thu 2018-04-26 17:07:10 CEST; 2s ago
  Process: 11218 ExecStart=/opt/wapt/bin/python /opt/wapt/waptserver/waptserver.py (code=exited, status=1/FAILURE)
 Main PID: 11218 (code=exited, status=1/FAILURE)
Apr 26 17:07:10 wapt systemd[1]: waptserver.service: Failed with result 'exit-code'.
Apr 26 17:07:10 wapt systemd[1]: waptserver.service: Service hold-off time over, scheduling restart.
Apr 26 17:07:10 wapt systemd[1]: Stopped WAPT Server startup script.
Apr 26 17:07:10 wapt systemd[1]: waptserver.service: Start request repeated too quickly.
Apr 26 17:07:10 wapt systemd[1]: Failed to start WAPT Server startup script.
Apr 26 17:07:10 wapt systemd[1]: waptserver.service: Unit entered failed state.
Renaud Counhaye,
, Ymagis Group
renaud.counhaye
May 2, 2018 - 08:41
Okay.
For some reason I don't know, the permissions on the /etc/ssl/private folder had become incorrect.
What was blocking the start of the service "postgresql@9.6-main.service"
● postgresql@9.6-main.service - PostgreSQL Cluster 9.6-main
   Loaded: loaded (/lib/systemd/system/postgresql@.service; disabled; vendor preset: enabled)
   Active: failed (Result: exit-code) since Wed 2018-05-02 08:32:10 CEST; 20s ago
  Process: 8843 ExecStart=postgresql@9.6-main --skip-systemctl-redirect 9.6-main start (code=exited, status=1/FAILURE)
May 02 08:32:10 wapt systemd[1]: Starting PostgreSQL Cluster 9.6-main...
May 02 08:32:10 wapt postgres[8848]: [1-1] 2018-05-02 08:32:10.305 CEST [8848] FATAL:  could not access private key file "/etc/ssl/private/ssl-cert-snakeoil.key": Permission denied
May 02 08:32:10 wapt postgresql@9.6-main[8843]: The PostgreSQL server failed to start. Please check the log output:
May 02 08:32:10 wapt postgresql@9.6-main[8843]: 2018-05-02 08:32:10.305 CEST [8848] FATAL:  could not access private key file "/etc/ssl/private/ssl-cert-snakeoil.key": Permission denied
May 02 08:32:10 wapt postgresql@9.6-main[8843]: 2018-05-02 08:32:10.305 CEST [8848] LOG:  database system is shut down
May 02 08:32:10 wapt systemd[1]: postgresql@9.6-main.service: Control process exited, code=exited status=1
May 02 08:32:10 wapt systemd[1]: Failed to start PostgreSQL Cluster 9.6-main.
May 02 08:32:10 wapt systemd[1]: postgresql@9.6-main.service: Unit entered failed state.
May 02 08:32:10 wapt systemd[1]: postgresql@9.6-main.service: Failed with result 'exit-code'.
And so the WAPT server also failed to start without its SQL manager (assuming that's the case).
Perhaps the WAPT server lacks a proper exit code to point the finger at this culprit.
Renaud Counhaye,
, Ymagis Group
May 2, 2018 - 08:43
thank you for this feedback.
renaud.counhaye
May 2, 2018 - 09:05
Hello again,
Unfortunately, I still have this problem:
2018-04-26 09_48_33-WAPT console.png (5.32 KB) Viewed 15408 times
I'm going to try reinstalling the software :?
Renaud Counhaye,
, Ymagis Group
May 2, 2018 - 09:13
You should check the waptconsole.ini file
%LOCALAPPDATA%\waptconsole\waptconsole.ini
to see if there's a timeout parameter with a decimal value.
If so, remove the decimal part.
You mentioned earlier that this problem appeared after importing packages...
Do you remember which packages and from which repository?
renaud.counhaye
May 2, 2018 - 10:06
Indeed, there are no decimal places in the .ini file. However, I did import some old packages from my old private WAPT 1.3 repository to this new 1.5 repository, having read that it was possible. But I may have missed a step in the process...
I just did a
sudo wapt-scanpackages -f -ldebug /var/www/wapt
Just to check, I don't suspect any fatal errors:
rcounhaye@wapt $ sudo wapt-scanpackages -f -ldebug /var/www/wapt
2018-05-02 09:54:12,869 INFO Processing new /var/www/wapt/ymg-teamviewer-full_13.0.5640.0-8_all.wapt
2018-05-02 09:54:12,983 INFO Processing new /var/www/wapt/ymg-teamviewer-host-only_13.0.5640.0-17_all.wapt
2018-05-02 09:54:13,116 INFO Processing new /var/www/wapt/ymg-viscosity_1.7.8-39_all.wapt
2018-05-02 09:54:13,146 INFO Processing new /var/www/wapt/ymg-disable-ipv6_1.0-5_all.wapt
2018-05-02 09:54:13,148 DEBUG Unable to extract icon for /var/www/wapt/ymg-disable-ipv6_1.0-5_all.wapt:no icon.png found in package name /var/www/wapt/ymg-disable-ipv6_1.0-5_all.wapt
2018-05-02 09:54:13,149 INFO Processing new /var/www/wapt/ymg-wapt-schtask-auto-upgrade_6_all.wapt
2018-05-02 09:54:13,152 INFO Processing new /var/www/wapt/ymg-java8_8.171-2_all.wapt
2018-05-02 09:54:13,523 INFO Processing new /var/www/wapt/ymg-SAP74_7.4.3-24_all.wapt
2018-05-02 09:54:14,513 INFO Processing new /var/www/wapt/ymg-vpn-schrewsoft_2.2.2-3_all.wapt
2018-05-02 09:54:14,572 DEBUG Unable to extract icon for /var/www/wapt/ymg-vpn-schrewsoft_2.2.2-3_all.wapt:no icon.png found in package name /var/www/wapt/ymg-vpn-schrewsoft_2.2.2-3_all.wapt
2018-05-02 09:54:14,573 INFO Processing new /var/www/wapt/ymg-BizagiModeler-32_3.1.11.0-2_all.wapt
2018-05-02 09:54:15,389 INFO Processing new /var/www/wapt/ymg-add-YMCA-autolaunch_0.8_all.wapt
2018-05-02 09:54:15,393 INFO Processing new /var/www/wapt/ymg-ms-teams_1.1.0.2253-0.1_all.wapt
2018-05-02 09:54:15,855 INFO Processing new /var/www/wapt/ymg-check-point-vpn_98.60.276-7_all.wapt
2018-05-02 09:54:15,902 INFO Processing new /var/www/wapt/ymg-python27_2.7.14-2_all.wapt
2018-05-02 09:54:16,022 INFO Processing new /var/www/wapt/ymg-pyscripter_3.3.2-14_all.wapt
2018-05-02 09:54:16,077 INFO Processing new /var/www/wapt/ymg-FsFInventory_0.7_all.wapt
2018-05-02 09:54:16,137 DEBUG Unable to extract icon for /var/www/wapt/ymg-FsFInventory_0.7_all.wapt:no icon.png found in package name /var/www/wapt/ymg-FsFInventory_0.7_all.wapt
2018-05-02 09:54:16,137 INFO Processing new /var/www/wapt/ymg-7zip_18.1.0.0-3_all.wapt
2018-05-02 09:54:16,149 INFO Processing new /var/www/wapt/ymg-adobeair_27.0.0.124-2_all.wapt
2018-05-02 09:54:16,214 INFO Processing new /var/www/wapt/ymg-addfont_0.9_all.wapt
2018-05-02 09:54:16,227 INFO Processing new /var/www/wapt/ymg-Office2016-launcher-english_1.1_all.wapt
2018-05-02 09:54:16,346 INFO Processing new /var/www/wapt/ymg-BizagiModeler_3.1.11.0-2_all.wapt
2018-05-02 09:54:16,349 INFO Processing new /var/www/wapt/ymg-waptupgrade_1.5.1.23-7_all.wapt
2018-05-02 09:54:16,458 INFO Processing new /var/www/wapt/ymg-BizagiModeler-64_3.1.11.0-2_all.wapt
2018-05-02 09:54:17,009 INFO Processing new /var/www/wapt/ymg-FileMakerPro16-x32_16.0.1.162-5_all.wapt
2018-05-02 09:54:18,534 INFO Processing new /var/www/wapt/ymg-waptdev.wapt
2018-05-02 09:54:18,562 INFO Processing new /var/www/wapt/ymg-windowsupdate-no-ads_13_all.wapt
2018-05-02 09:54:18,565 INFO Processing new /var/www/wapt/ymg-dotnetfx4.6_4.6.2-7_all.wapt
2018-05-02 09:54:18,738 DEBUG Unable to extract icon for /var/www/wapt/ymg-dotnetfx4.6_4.6.2-7_all.wapt:no icon.png found in package name /var/www/wapt/ymg-dotnetfx4.6_4.6.2-7_all.wapt
2018-05-02 09:54:18,738 INFO Processing new /var/www/wapt/ymg-ff-ggl-intranet_1.0-13_all.wapt
2018-05-02 09:54:18,743 INFO Processing new /var/www/wapt/ymg-add-YMCA-desktop_0.5_all.wapt
2018-05-02 09:54:18,746 INFO Processing new /var/www/wapt/ymg-telephony-fuze_1.11_all.wapt
2018-05-02 09:54:18,967 INFO Processing new /var/www/wapt/ymg-dotnetfx4.7_4.7.2046-9_all.wapt
2018-05-02 09:54:19,141 INFO Processing new /var/www/wapt/ymg-Office2016-launcher-deutch_1.1_all.wapt
2018-05-02 09:54:19,262 INFO Processing new /var/www/wapt/ymg-FileMakerPro16-x64_16.0.1.162-5_all.wapt
2018-05-02 09:54:20,886 INFO Processing new /var/www/wapt/ymg-OutlookSignatureFix_1.0-2_all.wapt
2018-05-02 09:54:20,888 DEBUG Unable to extract icon for /var/www/wapt/ymg-OutlookSignatureFix_1.0-2_all.wapt:no icon.png found in package name /var/www/wapt/ymg-OutlookSignatureFix_1.0-2_all.wapt
2018-05-02 09:54:20,889 INFO Processing new /var/www/wapt/ymg-chrome_66.0.3359.117-3_all_all.wapt
2018-05-02 09:54:21,340 DEBUG Unable to extract icon for /var/www/wapt/ymg-chrome_66.0.3359.117-3_all_all.wapt:no icon.png found in package name /var/www/wapt/ymg-chrome_66.0.3359.117-3_all_all.wapt
2018-05-02 09:54:21,340 INFO Processing new /var/www/wapt/ymg-Office2016-launcher-french_1.1_all.wapt
2018-05-02 09:54:21,437 INFO Processing new /var/www/wapt/ymg-SAP-BO_1.21_all.wapt
2018-05-02 09:54:21,729 INFO Processing new /var/www/wapt/ymg-SAP-config-files-wapt_1.0-10_all.wapt
2018-05-02 09:54:21,732 DEBUG Unable to extract icon for /var/www/wapt/ymg-SAP-config-files-wapt_1.0-10_all.wapt:no icon.png found in package name /var/www/wapt/ymg-SAP-config-files-wapt_1.0-10_all.wapt
2018-05-02 09:54:21,732 INFO Processing new /var/www/wapt/ymg-vlc_2.2.6-5_all.wapt
2018-05-02 09:54:21,917 INFO Processing new /var/www/wapt/ymg-ymagis-signature-updater_1.6_all.wapt
2018-05-02 09:54:21,920 INFO Processing new /var/www/wapt/ymg-proscope16_16.0.3.0-6_all.wapt
2018-05-02 09:54:22,230 INFO Processing new /var/www/wapt/ymg-avid-codecs_2.7.3.39175-1_all.wapt
2018-05-02 09:54:22,282 DEBUG Unable to extract icon for /var/www/wapt/ymg-avid-codecs_2.7.3.39175-1_all.wapt:no icon.png found in package name /var/www/wapt/ymg-avid-codecs_2.7.3.39175-1_all.wapt
2018-05-02 09:54:22,283 INFO Check / update CRL for embedded certificates
2018-05-02 09:54:22,283 INFO Writing new /var/www/wapt/Packages
2018-05-02 09:54:22,286 INFO Finished
2018-05-02 09:54:22,286 INFO Set Packages file ownership to wapt
I've put in bold the ones I've imported.
Renaud Counhaye,
, Ymagis Group
