[SOLVED] Console crash
renaud.counhaye
Registration: December 13, 2017 - 11:45
May 2, 2018 - 10:08
The most amazing thing is that if I type a search into the console, it works.
2018-05-02 10_07_31-WAPT console.png (9.71 KB) Viewed 9857 times
This only happens if I leave the search field empty.
2018-05-02 10_08_02-WAPT console.png (14.91 KB) Viewed 9857 times
Renaud Counhaye,
Network Systems Technician,
Central Functions Division
, Ymagis Group
May 2, 2018 - 10:17
Can you enable debug mode (View / Preferences / Show debug information, and also check "Show debug information" at the bottom of the window, which increases the log level to DEBUG)?
Then refresh the packages in the Private Repository tab.
And retrieve the trace at the bottom of the window.
renaud.counhaye
May 2, 2018 - 10:31
Here's what happens next:
  File "C:\Program Files (x86)\wapt\waptpackage.py", line 1895, in search
    for package in sorted(result,reverse=True,cmp=sort_no_version):
  File "C:\Program Files (x86)\wapt\waptpackage.py", line 1890, in sort_no_version
    return cmp((package1.package,package1.architecture,package1.locale,package1.maturity,PackageVersion(package1.version)),(package2.package,package2.architecture,package2.locale,package2.maturity,PackageVersion(package2.version)))
  File "C:\Program Files (x86)\wapt\waptpackage.py", line 231, in PackageVersion
    return (Version(version_build[0],4),int(version_build[1]))
ValueError: invalid literal for int() with base 10: '0.1'
Renaud Counhaye,
, Ymagis Group
May 2, 2018 - 10:37
OK...
The version number decoding doesn't like versions in the form !
1.2.3-0.1
(the second part after the hyphen must be an integer).
One of the culprits is:
/var/www/wapt/ymg-ms-teams_1.1.0.2253-0.1_all.wapt
. It needs to be edited and the ".1" removed.
I'll add a test to make sure the version has the correct format in the package build.
The version must be either
pure integer: 1 (
version only), 1.2.3.4
(version-packaging), or 1.2.3.4-1
(packaging is an integer)
renaud.counhaye
May 2, 2018 - 11:17
Ah, that's interesting!
I'm correcting it....
uploads...
[ /var/www/wapt ]
rcounhaye@wapt $ sudo rm ymg-ms-teams_1.1.0.2253-0.1_all.wapt
rcounhaye@wapt $ sudo wapt-scanpackages -f -ldebug /var/www/wapt
console relaunch + refresh software inventory...
Done.
And it looks like it's working! GG :)
Renaud Counhaye,
, Ymagis Group
