[RESOLVED] Reachable DISCONNECTED following update
julienlevi
Registration: May 4, 2018 - 09:18
May 4, 2018 - 09:25
Following the WAPT update from 1.5.1.22 to 1.5.1.23 on my Debian 9 Linux server,
all my machines appear as DISCONNECTED even though the status under 'Last seen on' indicates today's date.
The 1.5.1.23 agent has been successfully deployed, as well as the console.
WAPT Server version: 1.5.1.23
WAPT Agent version: 1.5.1.23
WAPT Setup version: 1.5.1.23
WAPT Deploy version: 1.5.1.23
Database status: OK (1.5.1.22)
Any ideas?
Thank you
May 4, 2018 - 11:02
there's a problem with the clocks not being set correctly: viewtopic.php?f=10&t=1057&p=3372&hilit=horloge#p3372 ?
julienlevi
May 4, 2018 - 11:14
Thank you so much!
After asking, I installed the NTP service, but it still didn't work.
So I added `signature_clockskew = 72000`
and it works!
May 4, 2018 - 1:29 PM
It would seem that either your server or your clients are not on time.
julienlevi
May 4, 2018 - 3:05 PM
Yes, it's strange. The BIOS clock is correct, but my Debian system is 2 hours ahead, even with the NTP service installed.
I manually reset the time on my Debian server, but the 'last seen on' timestamps are still 2 hours ahead.
