[Resolved] Package customization: Start menu
Jonattend
Registration: March 26, 2018 - 2:45 PM
March 26, 2018 - 3:00 PM
WAPT Server: Debian 9.0.3
WAPT Console: 1.3.1.3.0 on Windows 7 x64
WAPT Client: 1.3.13.0
Client machines: Running Win7 x32 or Win7 x64.
As a new WAPT user (thanks to JRES 2017 for the introduction), I would like to know if it is possible to customize the packages before installation?
I'd like to have shortcuts for office applications like LibreOffice placed in "C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Office Tools".
For multimedia software (VLC, Audacity, Format Factory, etc.), I'd like the Start Menu shortcuts to go to C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Multimedia Tools,
and so on.
I've seen that it's possible to edit the setup.py file, but for VLC, for example, I haven't found anything in either the setup.py file or the switches available in their installer.
How can I do this?
The idea is to create a post-installation, zero-touch package tailored to the target machine.
Thanks for any suggestions. :)
WAPT Server version: 1.8.1 on Debian 10
WAPT Agent version: 1.8.1.6756
WAPT Setup version: 1.8.1.6756 on Windows10 v1909
WAPT Deploy version: 1.8.1.6756
agauvrit
Registration: Nov 17, 2016 - 10:25
March 26, 2018 - 4:34 PM
The easiest way is to delete the shortcuts at the end of the package installation and recreate them in the desired locations.
See the documentation: https://www.wapt.fr/fr/doc/CreationPaqu ... shortcuts
Alexandre
Jonattend
March 26, 2018 - 4:59 PM
unless I'm mistaken, we're talking about shortcuts on the user's desktop, not in the Start menu... right?
The idea of ​​deleting and recreating the shortcut is perfect. But is that possible in the Start menu?
agauvrit
March 26, 2018 - 5:10 PM
My apologies, I read too quickly
For Start menu shortcuts, it's possible using the following functions: remove_programs_menu_shortcut And create_programs_menu_shortcut
Jonattend
March 27, 2018 - 08:15
Shame on me for not reading the entire document... I'll look into that and give feedback.
Thanks for the tip ;)
Jonattend
April 9, 2018 - 5:09 PM
what would be the correct syntax, for example, to create a VLC shortcut in the Start menu (All Users)\Multimedia Tools\?
In the `def install()` function, right after `remove_desktop_shortcut`, I'd be tempted to use `create_programs_menu_shortcut`, but I'm unsure about the arguments to pass... in the example with the WAPT Console, not all the arguments are used?
April 11, 2018 - 10:45
With Wapt 1.5.1.23:
    create_programs_menu_shortcut('VLC',target=makepath(programfiles64,'VideoLAN','VLC','vlc.exe'),folder=u'Outils multimédias')
vcardon
April 11, 2018 - 10:08 PM
Hello Jonattend,
Hubert suggests a solution using WAPT version 1.5, while you're currently on 1.3. There's a good chance Hubert's suggestion will work for you in the short term.
Your best option is to upgrade to 1.5. Version 1.5 is far superior to 1.3, and you'll receive reliable advice and suggestions every time.
At Tranquil IT, version 1.3 will quickly become obsolete because fewer and fewer public repositories will provide ready-to-use packages for WAPT 1.3.
Version 1.5 is really good and doesn't justify staying on 1.3.
Regards,
Vincnet
Jonattend
April 12, 2018 - 1:51 PM
thank you for your replies.
When I wrote this request, I was indeed on version 1.3, but I've since upgraded to 1.5 :D (see signature)
. I'll run some tests and post an update. ;)
Jonattend
May 11, 2018 - 4:04 PM
I was (finally) able to run some tests again... and it works :)
I'm posting my memo here, which might be useful to others in need:
WAPT: Modify an application shortcut: example: the VLC shortcut should land in Programs\Multimedia Tools\
- Open the setup.py file using PyScripter
- in the "def install()" section, insert:
 print("Creation du raccourci vers Outils Multimedias ....")
  # creation du raccourci dans le menu demarrer, programmes, outils multimedias ...
  create_programs_menu_shortcut('VLC',target=makepath(programfiles64,'VideoLAN','VLC','vlc.exe'),folder=u'Outils Multimedias')
  # suppression du raccourci de l application dans le menu demarrer, programmes ... sinon deux raccourcis seront créés : celui par défaut et celui qu'on a ajouté
  remove_tree(r'C:\ProgramData\Microsoft\Windows\Start Menu\Programs\VideoLAN')
- save the changes
- Perform a test on the test machine via Run Configurations, install
- If the test is OK, run Configurations, -i-build-upload to upload the package to the server
Result: when installing VLC via WAPT, the shortcut will go in Programs\Multimedia Tools.
Thank you for your help :)
