I tried launching the WAPT server in development mode. There are a lot of hardcoded paths, some custom methods, etc., and I thought there might be a trick.
Do you have any documentation or tutorials for launching the server in development mode?
Thanks in advance!
Waptserver: Development
- WAPT Expert
Hello Aguay,
So saying that there are hard-coded paths is in my opinion a misinterpretation... As for custom methods, yes the code to properly manage installations under Windows is not trivial, but it remains quite clean, Hubert is constantly refactoring.
For your information, development is primarily done on Windows with a WAPT path in c:\tranquilit\wapt... This is neither the new standard path (c:\program files\wapt) nor the old one (c:\wapt, which also works), and in fact, you can install WAPT 1.5 pretty much anywhere you want (there was a bug in the past when it was installed on a different drive) as long as it's based on a drive letter (C:, D:, etc.). Indeed, I don't believe UNC paths are supported everywhere in the configuration, however.
I don't think we have that, but if you'd like to write one, we'd be happy to include it in the overall documentation.
Thank you for the quick reply!
So, is it not possible, or only with greater difficulty, to launch the WAPT server in development mode under Linux?
Aguay
Aguay
dcardon wrote: ↑May 22, 2018 - 3:53 PM Hello Aguay,
