Error message: Error getting packages
mohondit
Registration: May 4, 2018 - 10:10
May 25, 2018 - 10:49
Since I updated to version 1.5, I have several messages of this type appearing on my server; the messages do not remain for long (less than 2 seconds approximately).
I don't know what it corresponds to, I barely have time to click on it to get a little more information before the message disappears.
WAPT ERROR.png (12.49 KB) Viewed 7789 times
THANKS
May 25, 2018 - 7:02 PM
Can you provide the contents of the wapt-get.ini file for the post?
mohondit
May 28, 2018 - 08:19
Here is the content of the wapt-get.ini file: (I changed my server name and domain name for security reasons)
[global]
waptupdate_task_period=120
use_hostpackages=1
repo_url=https://myserver.mydomain.lan/wapt
wapt_server=https://myserver.mydomain.lan
private_key=c:\private\mykeyname.pem
templates_repo_url=http://wapt.tranquil.it/wapt
default_sources_root=c:\waptdev
default_package_prefix=myprefix
loglevel=warning
allow_cancel_upgrade=0
send_usage_report=1
use_kerberos=0
check_certificates_validity=1
verify_cert=0
[options]
server_uuid=2de1077c-a803-4906-80a7-4afd9d155fb9
[wapt-templates]
verify_cert=1
flobro94
July 20, 2018 - 3:34 PM
did you find a solution for this kind of problem? Because I'm experiencing the same issue.
July 23, 2018 - 12:38
In my opinion, it's simply that the workstation doesn't have a machine package on the server.
