I'm trying to create a REG_BINARY registry key in a package.
I've tried the following without success: registry_set(HKEY_LOCAL_MACHINE, r'SOFTWARE\', r'test', a1, REG_BINARY).
Does anyone have a solution?
Thanks in advance.
srvwapt 1.5.23 on Debian Stretch, console on Windows 7
REG_BINARY
- WAPT Expert
Hello Bertrand,
You just need to add the following line to the beginning of the setup.py file
I've had to do this before, and it wasn't very straightforward. I don't think the setuphelpers API currently allows it, but you can directly call the winreg library in your setup.py file.Bertrand26 wrote: ↑May 23, 2018 - 9:30 PM I'm trying to create a REG_BINARY registry key in a package.
I tried unsuccessfully: registry_set(HKEY_LOCAL_MACHINE, r'SOFTWARE\', r'test', a1, REG_BINARY)
Thanks in advance.
import winregDenis
