We recently added a second RDS 2012R2 server to our environment, and for simplicity, we cloned it. However, WAPT doesn't like this because the UUID is the same for both servers.
The reset UUID command doesn't work because both virtual servers use the same BIOS UUID. I would like to use the `use_fqdn_as_uuid` function, but I don't know where to configure it. I tried `use_fqdn_as_uuid=1` in the agent's INI file and `use_fqdn_as_uuid=true` in the server's INI file, but it makes no difference.
Thank you in advance.
[SOLVED] UUID Issue with HyperV RDS Clone Server
- WAPT Expert
That's right:
in wapt-get.ini in the global section
Next:
Note: only compatible with version 1.5 of Wapt.
use_fqdn_as_uuid=1in wapt-get.ini in the global section
Next:
net stop waptservice
net start waptservice
wapt-get register
