do you have any idea what's causing this error? "
Unable to get https server certificate for url https://wapt.xxxxxx.xxxx gaierror: [Errno 11004] getaddrinfo failed" when retrieving the certificate in the local WAPT Configuration window.
Thank you.
Best regards,
Anne-Laure
- WAPT Expert
Hello Anne Laure,
For me, it's the same problem as the other threads. There's a DNS resolution issue on the machine. Could you replace the DNS name with the WAPT server's IP address?
You took my remark that it's better to ask only one question per topic a little too much to heartalf wrote: ↑June 4, 2018 - 4:41 PM Do you have any idea what is causing this error?
Unable to get https server certificate for url https://wapt.xxxxxx.xxxx gaierror: [Errno 11004] getaddrinfo failed when retrieving the certificate in the local WAPT Configuration window.
