[SOLVED] Windows 10 Driver
agatoi
Registration: Apr 05, 2017 - 12:03
June 7, 2018 - 7:17 PM
I am having trouble installing drivers for Esao Jeulin consoles on Windows 10 64-bit systems.
However, the package works on Windows 7
This installation causes the error: Warning: CalledProcessErrorOutput()
The command-line installation goes smoothly, but there's a problem with the package:
whether it be:
    currentpath = os.path.dirname(os.path.realpath(__file__))
    print("Installation drivers")
    run_notfatal(r'C:\Windows\System32\pnputil.exe -i -a %s\Esao_64bits\EsaoUsb.inf' %currentpath)
Or
    run_notfatal(r'C:\Windows\System32\pnputil.exe /add-driver %s\Esao_64bits\EsaoUsb.inf /install' %currentpath)
June 7, 2018 - 8:48 PM
https://www.wapt.fr/en/doc-1.5/Creation ... edirection
agatoi wrote: June 7, 2018 - 7:17 PM
with disable_file_system_redirection():
    run_notfatal(r'C:\Windows\System32\pnputil.exe -i -a %s\Esao_64bits\EsaoUsb.inf' % basedir)
For explanation: wapt is a 32 bit application, Windows will therefore provide a modified view of the system: system32 is therefore redirected.
https://msdn.microsoft.com/fr-fr/librar ... s.85).aspx
with disable_file_system_redirection(): provided the correct view to wapt
agatoi
June 8, 2018 - 12:26
That was it, thank you Simon!
