Agent generation impossible (SSL error)
Greg5689
Registration: June 11, 2018 - 4:17 PM
June 11, 2018 - 4:23 PM
Following the installation of the WAPT 1.5 server, I am trying to create an agent via the console. Everything goes smoothly during compilation until I am prompted for the key. I enter it correctly, the compilation resumes, and then a dialog box opens with an error for which I cannot find a solution.
Error: An unhandled exception has occurred.
Unable to create WAPT update package.
ConnectionError: ("bad handshake: Error("bad handshake: Error(['SSL routines', 'ssl3_get_record', 'wrong version number')],)").
I tested access to https ://localhost:443 and it works.
The server is installed on a clean virtual machine. We were previously working with version 1.3 without any problems.
Awaiting a possible solution,
thank you.
June 12, 2018 - 08:46
Have you enabled https verification?
Greg5689
June 12, 2018 - 09:27
No, I haven't activated it... I don't understand.
Information: The server is installed in a school. We use the Kwartz interface, so I opened certain ports to allow access to WAPT. However, this worked with version 1.3. There may be some changes to make in the new version...
AlbanUCA
Registration: May 28, 2018 - 12:21
November 26, 2018 - 4:00 PM
have you found a solution?
We are currently validating the solution in production, but unfortunately, after creating our various keys, we are getting this error message when creating the agent.
Alban
AlbanUCA
November 26, 2018 - 5:03 PM
Hi,
we had the same problem creating an agent.
I disabled the proxy for accessing the WAPT server.
The agent was created directly.
I hope this is a good solution.
Alban
November 26, 2018 - 5:49 PM
To be perfectly honest, I haven't had the chance to test Wapt with Qwartz.
Generally, we recommend installing Wapt on "a server dedicated solely to this purpose"
https://www.wapt.fr/fr/doc/wapt_server_ ... quirements.
It seems to me that Qwartz listens on interface 443.
