Hello everyone,
let me explain my problem:
I created a package using the WAPT console to be able to launch a software update on the workstations.
The package works.
My problem arises later, when I launch the package update on a test workstation (a workstation I have access to), I can see in the Task Manager that the installation is in progress. Once the task is complete, I launch my software to verify that it is up to date and I see that everything is OK, it is indeed the new version.
Having done that, I think it's perfect and quite easy to use.
However, when I return to my WAPT console, I go to the inventory, then to the workstation in question, and in the "General" tab, I can see my package name, and in the Install date and Installed by columns, everything appears correct, but the problem appears with the "Status" column where it constantly shows "NEED-UPGRADE". This is where I can't understand why the status never shows as OK, even though the update went through successfully.
I hope my explanation was clear enough.
Thank you for your help.
Have a good day
. Sincerely.
"Need upgrade" message after installing a package
