[RESOLVED] WSUS ID
vbirault
Registration: June 7, 2018 - 10:28
June 28, 2018 - 08:50
WAPT 1.5 server on Debian 9.4
Technical position in W7x64
We need to renew the WSUS IDs so that all the workstations appear in the console.
We found a script for this:
@Echo off
if exist %systemdrive%\SUSClientID.log goto end
net stop wuauserv
net stop bits
reg delete HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\WindowsUpdate /va /f  > %systemdrive%\SUSClientID.log
net start wuauserv
wuauclt.exe /resetauthorization /detectnow
:end
exit
It works when launched directly on the test machine, but when launched via pyscripter with a run command, the keys do not clear and I get an error message: 'wuauclt.exe' is not recognized as an internal command.
What are the differences between the two? Encoding issues? Rights issues?
June 28, 2018 - 7:35 PM
with disable_file_system_redirection():
	run('wsus.bat')
vbirault
June 29, 2018 - 08:21
thanks to you the package is now working.
Thank you for your help.
