uwsgi-core
jmeyer
Registration: March 30, 2015 - 3:15 PM
May 18, 2015 - 1:54 PM
I get the following error.
I updated to version 1.2 this morning but I don't know if that's related.
May 18 13:52:27 debian kernel: [  617.824017] Out of memory: Kill process 3263 (uwsgi-core) score 108 or sacrifice child
May 18 13:52:27 debian kernel: [  617.824333] Killed process 3263 (uwsgi-core) total-vm:160272kB, anon-rss:54936kB, file-rss:24kB
Thanks in advance.
jmeyer
May 18, 2015 - 3:56 PM
After some testing, with 1GB or 2GB of RAM, the problem persists.
The previous message is due to memory saturation at the very beginning of the machine's startup.
If I stop the waptserver service, the memory is freed.
jmeyer
May 19, 2015 - 08:55
New info, I have about 15 instances of uwsgi-core which take up about 5% of the RAM each.
Is it possible to reduce or limit the number of simultaneous instances?
Yvan Karmouta
Registration: June 18, 2014 - 10:09
May 20, 2015 - 09:09
How many Wapt customers do you have?
At the end of your update, did you restart the postconf script?
python /opt/wapt/waptserver/scripts/postconf.py
Yvan Karmouta - Tranquil IT Systems
Feel free to leave us your opinion on Wapt in the forum, or to answer our questionnaires :).
jmeyer
May 20, 2015 - 11:02
I have between 250 and 300 WAPT clients.
I just restarted the script, but I don't think I ran it after updating from 1.1 to 1.2 as indicated in the documentation.
jmeyer
May 21, 2015 - 08:47
I just migrated to a new server where I installed 3GB of RAM and 4 cores.
The problem seems to be solved.
